Thread: How to install TPS?
    Senior Member G.C's Avatar
    Forgot
    Default How to install TPS?
    Dads friend scanned the CEL that was throwing on my car. and he said its the TPS. so i bought a new one and was wondering how to install it. heard bout it has to match certain voltage? how would you do that? I thought all you had to do was unscrew the 2 screw and take it off and replace it.
    :idb:
    clayton county
    Quote Originally Posted by G.C
    you just said it yourself lol
    I give out reps....
    Forgot
    i was just wondering bout the voltage thing. how do you adjust it. and do you have to do it or you can just replace it and screw them back.
    :idb:
    Oct 2003
    ^^Self diagnostics FTW
    3.2L 24v DOHC One_Bad_SHO's Avatar
    Blacklanta
    Make sure to put a cover letter on that TPS report.
    Quote Originally Posted by One_Bad_SHO
    FAIL
    clayton county
    when you install the TPS, you can slightly move it around. move it around till it gets to the voltage you want then tighten
    I give out reps....
    Forgot
    thanks khaxnguyen. reps.
    :idb:
    DC5-R
    Gwinett
    use a voltmeter, closed throttle should read .5 and WOT should read 4.5. Use the voltmeter and tap it to the red wire, black can be any ground. Turn the key to the on position (not turn on the car), and have a pin or wire to the check engine plug. Thats it, fairly simple.
