Results 1 to 5 of 5
Thread: Cable & Hydro Pressue Plates
    Default Cable & Hydro Pressue Plates
    hey i was wondering are hydro b series and cable b series pressure plates all the same, only difference would be the 90-91 clutch disk because of the spine only for being smaller correct..and 92-01 b series clutch disk are all da same..!
    Stang Mod slostang's Avatar
    Southside
    dont quote me but I believe they are the almost the same, hydraulic and cable trannys are referring to either manually opening the clutch via lever and cable, as hydraulic systems use uses a hydraulic cylinder and lever system to open the clutch.
    E-Thug SouthSide Tay's Avatar
    SouthSide Atlanta
    pretty sure they are the same 92-01 b series disc no real worries there
    - SouthSide Tay
    93 Sonoma
    -350ci SBC/th350/edelbrock single plane intake/holley 600cfm/dual flowmaster/3.73 rearend/ Weld prostars/ 27x8 Hoosier Slicks
    Daily Driven
    they have different part #s from acura so i really dont think they are the samething. i dont deal with cable tranny often so see what somebody else says.
    i needa know becuz i got a exedy stg 2 hydro pressure plate and a 90-91 comp stg 2 clutch disk, if the hydro pressure plate works then i want to put it in if not then i dont feel like opening up the tranny....!
    lemme know somebody
