Results 1 to 4 of 4
Thread: Kickdown Cable/Throttle Valve
    Default Kickdown Cable/Throttle Valve
    Swapped the H22 in the CB and noticed it didn't want to change out of 1st sometimes and idle was ruff. So I went back in and set the timing again, with some assistance and now the idle is great and the shift points are better, however I was wondering if I could "fine tune" the shifting with the kickdown cable. Car pulls soooo nice. All the frustration from the last 14 months goes away when VTAK kicks in!!!
    yah u can adj the kick from the cable. just make a lil adj text drive dont like adj again. keep doing that till u find a spot u like.
    I'm guessing from how the cable is now, which is loose, that I want the cable tight?
    there should be some tension on it. not tight but not flopping.
