Okay, I thought I had it all sorted out, but it came right back.
my 97 DX has a D16Y7, and I've already done the tune up stuff
new plugs, wires, cap & rotor, lucas fuel injector cleaner, new o2 sensor, seafoamed the motor
the car when warm starts to buck and surge under load....
I have no problems when the car is cold....but let's say I drive the car around and run into the store and come right back out, the car at take off from a stand still starts bogging....you hear the motor revving real slow and the car will buck and then take off.
it usually happens like 7-8 times on my commute to work which is 80 miles....so I will be cruising at about 75mph which is 3500rpm and then the car's tach will bounce down and the car will buck and stutter until I give it more gas, and then it will clear up....and it'll happen down the road again, not immediately but it does.
everyone tells me different things to replace, but I'd like to know a sure answer before throwing more money at it....
so far the suggestions I have gotten....
map sensor
tps sensor
iacv
coil
but these items are all $100+ each, so I'd rather not spend $400+ on chasing this problem down
btw, the car is not throwing ANY codes and CEL is not on. The car has been scanned twice and nothing has come up.
any ideas?
and VtecKidd....ain't this irony....I'm asking you for your guidance! but you seem to be the know it all for honda's....so any guidance would be greatly appreciated.
just for old times sake no charge EL OH EL
ONE DAY
