i jsut put in some headers in my 97 civic and at high rpms it makes a hissing noise i was woundering if this is normal our is there a leak
probably a leak
Val for President
what should i do? make sure all the screws are in good or jsut take it up to a shop so it dont mess anything up?
did you change the tightening like up to down ans left to right?
like tighten the top right then bottom left and so on?
Val for President
and did u put on the gaskets?
Val for President
well im not hte one who put them on but when i get home i thought i would lossen them up to make sure the gaskets arnt messed up and then tighten them back up and see if thast whats wrong..but if i keep them liek this with the hissing will it mess anything up, but i kno the engein bay will get dirty quicker but other then that will it mess up
compression loss...worse gas mileage..number of things probably. They might not have made sure there was a good connection to the cat.
alright thanks for the help i didnt have time to check anything yesterday but i think im just going to take it up to a shop to get them to fix it
I'm curious if you've done a V8 swap or V6 swap in your civic since you have HEADERS. lol, just messing w/ you but in case you ever have to ask anything again it's a header on a 4 cyl, just trying to keep you from getting laughed at. Also, find out what they torqued the bolts to and make sure that they are to spec. Also, make sure they do it in an alternating pattern when tightening. The stock manifold gasket has worked well so far on my car and I've been through two different headers as well as taking each of them off and back on several times.
thanks for the help
