Results 1 to 6 of 6
Thread: help!!! trouble starting
    Senior Member EJdm's Avatar
    Default help!!! trouble starting
    bought d16z6 motor from IA member couple months ago, i swap my jdm head on it, put in a new head gasket from honda, new plugs and wires...finally everything is in except axles wanted to see if it'll start and its having a hard time starting...please help...timing is good, i have spark, gas is also good...
    here a video of it...check it out...
    http://s136.photobucket.com/albums/q...rent=d16z6.flv
    now it wont even start...all you hear is a clicking noise...how could this be??? i'll check timing 2morrow morning...
    SOUTHSIDE
    my guess timing or firing order on the spark plug wires
    Certified Gearhead EK Hotch's Avatar
    Canton
    x2 on the firing order^
    Swamp
    Newbie Photodude RBS's Avatar
    All Over U S A
    check timing, firing order, cap/rotor, and then replace your fuel filter... fuel filter is a very common overlooked problem
    do a compression test on the motor. The clicking noise is your starter, if you try to start your car too much, it will do that.
