Results 1 to 7 of 7
Thread: 91 SI Cluster Problem
    Default 91 SI Cluster Problem
    hey i was driving my car, nothing wrong but next morning parts of the cluster wasn't working no more like, tachmeter, gas meter, and temp meter, but the backlight works and speedmeter works, only light i see on is the batter light when the key is on acc, nothing else works or lights up let me know what might be the problem
    *checked all fuses but they all are good, nothing blown.
    *also timer doesnt work only if i hold on to the button it shows the time
    *turn signals dont work, only on when i press the emergency
    help me out please...!
    GetItFixItFlipIt Timinater's Avatar
    where you located? maybe a ground loose?
    It's all about JDM.
    CA to GA
    did you check the fuses in the engine bay and under dash. Next, use a volt or electrical light tester to test the fuse (I think its the cluster or interior light fuse) if its blown or not. (sometimes looking at a fuse is deceiving, some look unblown but really they short circuited) Check loose wires or plugs...hope this help man.
    IA Junior Member JDM-95-Hatch's Avatar
    Kennesaw GA
    another thing it could be is the ignition switch going bad... sounds like one of the accessory circuits may be bad
    for all the response..thanks....but then i used a fuse tester all fuses are good....i've checked the cluster to see if the harness is loose but nothing is loose everything is good, im going to try putting another cluster in to see if it solves the problem...!
    didnt solve problem....what the heck could be wrong........just got a ticket earlier for no turn signaling.....dammm........HEEEELLLLLLLPPP.....!
    ttt
