Thread: civic powersteering and A/C problem
    E38 740i M fininfarina's Avatar
    Default civic powersteering and A/C problem
    My civic hatch CX does not have powersteering
    anyone knows how and what do I need to have to conversion that??
    the car has B18 on it.
    And A/C worked well before but I tried yesterday, not work
    don't know what is wrong with it
    Heater works good
    when I turned on A/C, can not hear any just blowing.
    Senior Member HatchHero's Avatar
    Atl
    you will need a power steering rack and pinion off a EX, the pump and resevoir, and lines and components that go along with it...like the bracket and everything! should just bolt up.. but with the b series u might need the b series pump and extend the power steering fluid line... i would call battleground for more info! if you use the b series pump you need to mate the b series line to the civic line! that needs to be welded or brazed on or somethin like that.. did your civic come with power steering????
    and you might need freon for your AC
    Nope it was not come with powersteering
    Thanks for the answer
    Atl
    so the car never came with P/s
    I've done with those problem
    Thanks IA
