Thread: att. Mr.kid... obd2 trouble.please help
    otp
    Default att. Mr.kid or anyone obd2 trouble.please help
    ok so i got a 98 civic wit a d16y8 in it. it has a trashed bottom end, i have a d15b2 block and head that are good, wat do i have to do to get it to work? i know i need a obd2 single cam non vtec ecu, but will that ecu work wit the d15b2? i have the obd2 dist. and the intake main. and the wiring harness. the biggest thing i have a concern wit is it not beaning able to be emission tested. anyone have any in put wit wat i can do? and if anyone has the ecu i need id gladly trade the vtec ecu. get back to me asap. if anyone wants to help me further than please pm me. thanks...
    ps mods hope i did this right.. please dont delete.
    otp
    bump please.... also edit to the first post. if i want to do i guess wat is called a mini me swap is there any michning that has to be done like wen u do a ls vtec?? lmk asap.. reps go out to whom ever helps!!!!
    otp
    Quote Originally Posted by tubby
    do you know anything about the kfc splice i have been reading about?
    http://technet.ff-squad.com/ckftrick.htm?
    this is wat your talkin about? im in a bind here, the car im Putin the engine in is for one a 98 civic and it is the owners of the company i work fors car, lol so i got this long block wit his money, and now i just have to get it to work some how...
    your moms house
    no it will not pass emissions because the newer d16 has a crank shaft sensor on the oil pump and the older d15 has the crank sensor in the dizzy. so in short it will have check engine lights
    otp
    well F**K anyone wana trade a d15b2long block for a d15y8 short block?? pm me please
    Marietta, GA
    bumps.... cant help you there buddy. good luck though
    LAWRENCEVILLE
    dont forget the y8 has a knock sensor and the b2 will not have a spot for it.
    Hella stock member!
    otp
    so really i cant use the b2? lol dam this sucks.. anyone got a y8 short block they wana trade for a d15b2?? please.. and am i gona be able to slapthe y8 head on the b2 block without takin it to the machine shop? im confused on wat i have read. dont the single cam non vtec block have the oil jet there already?
    Your moms house
    Honda-tech is your friend.....
