im looking to do a swap in my 95 civic coupe and this is my 1st swap so i need alittle help... what all do i need... Im looking to do a LS swap...
a full swap meaning mounts, harness, axles, halfshaft, ecu... i might be missing some things....
^^ i think u're missing a shift linkage and the whole engine! ******lol*******
Last edited by khaxnguyen; 02-04-2008 at 06:17 PM. Reason: forgot "lol" people getting angry here.. lol
I give out reps....
x2Originally Posted by khaxnguyen
Lsu tigers going # 1 again
Stop Being Smart I'll Kick Your AsssOriginally Posted by khaxnguyen
yup everything has been pretty much covered by the last few posts.
Just to recap.
You must have all of these
1:LS Engine
2:Bseries Transmission
3:Bseries Midshaft and Axels
4: Shift Linkage
5:Wiring Harness(but that should come with the motor, and you might be able to use your civics wiring harness, since its obd1)
You can also put an OBD2 motor in there, they are backwards compatible.
6:the exhaust line, cat to resonator.
The mounts are the same on OBD1s between Dseries and Bseries.
I suggest doing this, check some auctions find a wrecked integra and get the swap from there, you will have everything you need.
blow me ^_^Originally Posted by ep9716
I give out reps....
