How do u know u need a new oil pump????
Because my oil light was flickering and i have no power
I change out my head gasket last night cause of leak
But its still doing it
				 Oil pump failure experienced engine builders check in please
				Did you ckeck your oil?
				What engine
What Mods
when was the oil pump last replaced? mileage?
need more info
				Yes i have change the oil last night
Its a stock b16a with 90k mile on it and had it since 55k miles
And i never change out the oil pump xince i had this motor
Im thinking i have no oil pressure
				WELL U WANT THE BAD NEWS!! more then likely you are going to need new bearings and crank now. $$$$$$$$$$$$$$$$$$$Originally Posted by Mr.Big
				First things first
1) Make sure your oil pressure sending unit isnt bad.
2) Get a mechanical gauge, and hook it up to the oil pressure sending unit an see how much oil pressure you have, you should have around 10-20psi at WARM Idel
Or, if you want just reaplce the $100 oil pump for insurance, if the light still comes on, at least you have piece of mind
				Preciate that KiDD !!!Originally Posted by Mr. KiDD
				Originally Posted by B18c1Turboed
I hope not
				Well the couple times we ahd that happen, the bearings where toast and so was the crank. Im pretty sure u better start shopping for a new crank and get some bearings!!Originally Posted by Mr.Big
When the oil light comes on,its becasue the motor went below i think 10 psi of oil pressure, that aint good for the motor!! hope it works out for u
				oil light is less than 5psi of pressure.
as long as there is no load on the engine, it really want do any damage.
if you do have low oil pressure an you drive the car around, it will cause the damage danny is talking about
				Ok everthing is off now
I have a jdm b16a
So i just got a b16a2(99-00 si) oil pump and it seems like it dont want to fit.. Does it fit???? And i put the old one back on and went on so easy
I heard that all b16's oil pumps fits
im taking my break now tried of f ucking with this car
				I just saw on the internet that the del sol b16 has more of the same parts
that fits the generation 1 jdm b16a
				yes it will fit...I got a type r oil pump
				also if the oil sender is bad...it will not hit vtec...so that is why you dont feel power, check the sender out also....hate you do all that work an sender is bad.....
				only thing different is the new one b16a2 has a crank sensor where yours doesnt...
				the type r oil pump is the same part number as the B16 B18c1 oil pump. You just pay more getting it from ACURA.Originally Posted by JoshuaASE
				Correct....I just buy the Top dollar ****t....LOL....But the b16a2 pump will work on your b16aOriginally Posted by SPOOLIN
				actually at my dealership, the type r pump is cheaper by a couple bucks...
Who knows?
				hold the engine at ~6k rpms, if it starts knocking then your oil pump is bad
Well it still did hit vtec
				I just order a b17 gsr oil pump Imma see if this pump fits
Oh i have a gen 1 b16a obd0
				well how bout that ****. Ive got Wholesale so actually, I get it cheaper, LOLOriginally Posted by hondabuilder
