Results 1 to 7 of 7
Thread: Type R swap
    not enough whips! BamzRexsi90's Avatar
    Question Type R swap
    If did a full Type R swap. Would i have to use the 5x100 lug pattern or could I still use the 4x100 pattern? I would rather keep my 4x100
    Flooding IA with JDM dc2teg2006's Avatar
    hard to understand what you have written. But if you are saying that would a Type-R swap fit without you having to do a lug conversion, then the answer is yes you can do that without the 5 lug conversion.
    yes that what i was saying. so what would i have to do for a ej1? Use the axles that come with the swap with my ej spindles? or what?
    Don Mon SiRed94's Avatar
    Morrow 30260
    it depends on if the swap was from a USMD Type R or JDM Type R ... JDM Type R's have 36mm axles and USDM Type R's have 32mm axles... if you have the USDM B18c5 swap then just use the axles that came with the swap, they will fit the 4x100 stock hubs...
    L'ville
    hasport can be your friendly store or even just your friendly swap guide
    RE30
    yes u can use your 4x100
    my momma's house
    96 ITR's had a 4x113.3 lug pattern...
    just my two cents
    Good Day!
    Trend settin'
