Results 1 to 8 of 8
Thread: Will a D16y7 fit directly in a 2000 civic ex without issues?
    Default Will a D16y7 fit directly in a 2000 civic ex without issues?
    Alright so the motor in my 00 civic ex just blew up,I need to no if a d16y7 will drop in without any issues I'm pretty sure it will just making sure, also if i were to get a y7 would i need to get the y7 ecu or would my y8 be alright thanks Mike
    BK ALL DAY
    You would have to do some wiring, because of the iacv differences. and of course not having vtec.
    GECKO SQUAD MEMBER
    MSS RACING REPRESENTA.....
    the saga continues....
    i'm a got dang wallaby!!
    question... why would you down grade? the y8 to MY knowledge was a better engine...
    [edit] D16Y7
    Found in:
    1996-2000 Honda Civic DX/VP/LX/CX
    1999 Honda Civic Special Edition - SE(Canada)
    1996-97 Honda del Sol S
    Displacement : 1593 cm³
    Bore and Stroke : 75 mm X 90 mm
    Compression : 9.4:1
    Power : 105 hp (78 kW) @ 5600 rpm
    Torque (ft·lbf@rpm): 95 (141 N·m) @ 3,800 rpm
    Valvetrain : SOHC
    Fuel Control : OBD-11 MPFI
    Head Code : P2F
    [edit] D16Y8
    Also available in New Zealand under the code D16Y6
    VTEC
    Found in
    1997-1998 Honda Civic EX Sedan
    1996-1998 Honda Civic EX Coupe
    1996-2000 Honda Civic EX (USDM)
    1996-2000 Honda Civic SI (Canada Only)
    1996-2000 Acura 1.6EL (Canada Only)
    1996-1997 Honda del Sol Si
    Displacement : 1590 cm³
    Compression : 9.6:1 Piston Code:P2P
    D16Y8 1.6 16V SOHC VTEC-II PGM-FI 1590
    126 hp@5900 rpm 108tq@4800 rpm
    Head Code : P2P
    VTEC crossover: 5300 rpm
    Redline 7200 rpm
    so why?
    clayton county
    yeah.. why?
    I give out reps....
    'Round These Parts
    Not a good look!
    Leisa and S. 4 Life NM?
    Downgrading because I found a y7 alot cheaper than I can find a y8, i just need to get my car running agian
    LAWRENCEVILLE
    yes and no i would not do it. you would need a y7 ecu. your y8 ecu will throw a code for vtec and the knock sensor that are not there on a y7. also the y7 and y8 also have diffrent intake manafolds so your intake will not work as well as other little issues like your th cable no working
    I think i talked to you today.
    You have to repin your ECU for the 3 wire IAC, and the intake tube is different.
    my swap comes with an ECU so i have you covered there and i can show you what to swap out
