Originally Posted by Blitanicle99
doesn't take that much hammer work.
and why throw a solid axle under a car with a perfectly good independent rear with nearly bulletproof rear end? the R200 diff is similarly beefy as a ford 9" internally. they've repeatedly held up well above 400ft-lbs of torque on sticky tires at dragstrips. at worst you'll break axle shafts for a u-joint, but a nice beefy set of aftermarket axles is much cheaper than retrofitting a solid axle into the car.
