Results 1 to 40 of 46
Thread: I need help
    RIP Leisa Lowenthal Shawna's Avatar
    Canton Ga
    Default I need help
    So my brakes went out yesterday morning on my way to work. I have basic knowledge of brakes but not enough to check them myself. I need one of you lovely gentlemen to please take a look at my brakes ans see if there is a reason behind why they went out.
    I have talked to a couple of ppl that have has a similar problem and they all say it the MC.
    VAL FOR PRESIDENT
    help a redhead, save a life
    Canton Ga
    lmao I will so buy beer
    VAL FOR PRESIDENT
    i think anything is offered to help w/ these brakes bump
    To check the brakes successfully in a severely cyanotic 7-year-old Japanese car who had a very rare type of double-outlet right ventricle. The malformation was associated with bilateral conus, 1-transposition of the great arteries, and subpulmonary ventricular septal defect without significant pulmonary stenosis in situs solitus. A large amount of subaortic conal musculature which separated the aortic valve from the subpulmonary ventricular septal defect was removed, as was the anterior rim of the ventricular septal defect. A tunnel, constructed with a woven Teflon prosthesis, was inserted in such a manner as to direct blood from the left ventricle through the defect and out to the aorta. The pulmonary outflow tract was reconstructed with a Teflon patch lined with pericardium. The car's postoperative recovery was uneventful, and it was doing well 3 months postoperatively. To our knowledge, no identical case with a similar type of surgical correction has previously been reported. Congratulations, you have checked your brakes. Now to fix them. Later, QD.
    Quote Originally Posted by BlackSiChic
    Thank you
    im just a messenger
    Yeah man. Fr33way's Avatar
    North OTP
    MC or pretty decent fluid leakage/ torn line.
    North OTP
    ^^^ If it wasn't clear you should check the fluid. (Use QD's write-up)
    Can't believe nobody has asked what the symptoms are
    Is there any metal on metal sounds? Does the pedal feel spongy or does it go straight to the floor? Does the pedal stick at the bottom? etc. etc.
    its the usual honda symptoms of what the pedal does...it slowly goes to the floor...MC. same thing thats wrong w/ my brakes. shes already bled her brakes before..so...
    Just have to pump about 1/2 way down 4-6 for full pressure then right?
    im not fully understanding what ur saying..but i think ur saying u gota pump the brakes to get pressure on the pedal right?? if so yea. cuz mine does the same
    To get enough brake pressure to stop you have to pump them a few times or does it not get pressure at all, that's what i was saying.
    gota pump it up a few times...or for instance while im at a stop light and i have my foot on the brake..itll slowly go down
    Canton Ga
    thank you sorry PBS is acting as my voice b/c I can only get on here when I am on the 3rd floor...
    this is the 2nd time this has happened both times it has been raining (not sure if it had anything to do with it) basically I go to stop and the car begins to slow down and then the brakes just give out and I start sliding. Ive noticed in the past couple of weeks that normal stopping takes a little longer that it used to. I am not one to ride my brakes or slam on my brakes if I am stopping I will gradually come to a stop. Both times I have either slid under the bumper or barley missed the car infront of me thank god...
    like I said I know how to change my brakes and all but past that I will admit I am clueless
    VAL FOR PRESIDENT
    So the tires are locking up? You sure it's the brakes and not the tires? Is there an ABS light on?
    Canton Ga
    no abs light. The tires aren't locking up at all I still have traction. My tires are brand new as well. I think the only reason why I am sliding is b/c the rd is wet.
    VAL FOR PRESIDENT
    North OTP
    ^^^ Yeah, sliding? More info?
    bump for blacksi to see
    North OTP
    That sounds like bad tires on wet road? How is braking feel?
    I dont know much about brakes but i can look at it .
    I can check the master cylinder, fluid, calipers. see if we can figure it out
    Canton Ga
    My tires have less than 6months of wear on them. my allignment is fine
    My brakes feel like I cant stop
    VAL FOR PRESIDENT
    but it's sliding/skidding?
    OK First things first. Answer these questions:
    1) DOES YOUR BRAKE PEDAL HAVE PRESSURE? WHAT WE MEAN IS, WHEN YOU PRESS IT, DOES IT GO ALL THE WAY TO THE FLOOR?
    2) DOES YOUR MASTER CYLINDER HAVE FLUID? IF NOT, REFILL AND RE BLEED
    3) MAKE SURE YOU DONT HAVE A BLOWN SEAL ON YOUR CALIPER, LOOK FOR FLUID ON YOUR TIRED USUALLY THE INSIDE (WHEN ITS NOT RAINING)
    4) BRING THE CAR BY HERE FRIDAY AND ILL LOOK AT IT
    Canton Ga
    yes it has pressure I press down and the brake and it seemed like they where woking but yea no such luck
    I dont get home until after dark and the light in my apt complex dont work so no such luck on the 2nd
    when is it not raining???
    I work until 530
    and this is why i love you
    VAL FOR PRESIDENT
    Ok so the pedal HAS pressure.
    but the brakes ARENT working. Might have an air bubble or something. did this just start all fo the sudden>
    Canton Ga
    yes sir...my brakes have been fine until a couple weeks ago
    VAL FOR PRESIDENT
    lol Mike to the rescue
    San antonio 210
    check ur master cylender or wheel cylenders
    Canton Ga
    mc has fluid btw
    VAL FOR PRESIDENT
    check and make sure you V-TECK matrix is hooked u properly lol
    Canton Ga
    umm I filled up my v-attack fluid yesterday thank you
    VAL FOR PRESIDENT
    eh you need d series v-tack.. did you know technically you could consider oil to be v-teck fluid?
    Canton Ga
    yes sir I guess you could technically
    i upgraded tho...i have pink vtack fluid
    VAL FOR PRESIDENT
    werd? specail order from pep boys?
    Canton Ga
    auto zone
    VAL FOR PRESIDENT
    damn i need some of that stuff. i wonder if it comes in hot pink?
    Canton Ga
    ummm thats what color I have....hello kitty cap too
    VAL FOR PRESIDENT
    werd? hook me up then!!!
