Results 1 to 31 of 31
Thread: Gas....
    Lilburn
    Default Gas....
    So I put $20.00 of gas into my Civic yesterday and I've only driven about 42 miles since. How much gas mileage do I get out of my Civic b/c my gauge is showing that it's on a quarter tank already!!! I know that is some bull**** b/c $20.00 worth in my Civic usually puts me a little over half considering the gas prices these days. Could there be something wrong with my gauge or do I have a leak?
    Weekly Gwinnett/Junciton Meet
    u sure u didn't select premium when u were putting gas in lol. Well could be you gauge, if there was a leak you would have smelled it by now. Try it couple more times...fill it up and see what it does.
    Lilburn
    Quote Originally Posted by UpSideDownDesi
    I know I'm a little slow at times, but I'm not that retarded! LOL
    I'm sure I put in Unleaded and this isn't the first time I've notice this.
    Quote Originally Posted by itsjustdee
    lol i wasn't saying u are retarted (maybe? jk). Well if it isn't the first time...then time to get it checked. I'd be too if a civic took qauter of a tank in 42 miles. U must have Super VTEC...put some more VTEC fluid in it. lol
    Lilburn
    LOL nooooo. My car is stock; no mods or anything. That's why I'm so concerned...
    Mannnn if I take it to a shop, they're gonna try and charge me an arm and a leg. Last time I took it to a shop, they wanted to charge me $300 for a tune up. Assholes.
    Straight up JDM!
    $20 on unleaded for me give me 3/4 of tank. and usually last me a week. yo I suggest you buy new oil filter or something.
    Lilburn
    Quote Originally Posted by jdm_91crx
    I just had a tune up and an oil change.
    soon to be fast
    im sure tire pressure kills mph without you knowing it.
    $300 for tune up *falls off his chair laughing* . Call the stealership...they'll tell you what it might be then after that i am sure someone here will knock it out for the low low.
    P.S how many miles on the civic and when was the last time u changed fuel filter and did the basic tune up...(plugs, air filter).
    Oct 2003
    Is the Check engine light on?
    Lilburn
    i had a friend of a friend do the tune up two weeks ago....he changed everything out and i had my oil changed that day too.
    Lilburn
    nope!
    my brake light is always on though....
    **H.I.D KING** Nitro's Avatar
    STMN GA
    put $20 gas in my car & i'll let you know.........personally i think it's yur fluxcapacitor
    Lilburn
    Quote Originally Posted by Nitro
    WHAT'S THAT?
    LOL^^^^^^^^^^^^
    WHAT'S THAT?
    its that thing u stole from me and george...how often do u chk ur mpg???
    the only way to do it RIGHT is to fill it all the way till it STOPS. fill it up an check how many GALLONS you paid for.
    now, reset the TRIP odometer. Usually civics have 11 gallon tanks. Look in your owners manual to be sure.
    drive it. You should be getting AT MINIMUM 25-30mpg. when you get to halfway note your mileage and divide it by half the tank. when you get to "E" divide your mileage by 11.
    that will tell you MILE PER GALLON.
    if its anything under 20MPG you have something seriously wrong or your gauge is Way off which is possible.
    for reference, $20 in my silvia BARELY gets me half a tank, BARELY.
    i put $20 bucks in my tank yesterday and i have a 99 civic, and it almost filled my tank up but whenever i look, it seems like i use a lot of gas...
    oh and it was on E yesterday
    im going to try that..thanks
    alot of this is because they are make the gas in cheaper ways to save them money which in turn gives ****ty milleage as well
    Lilburn
    I always keep a count on my mileage b/c I like to drive on E somtimes =X Haha.
    When I put $20, I usually get about 200 miles before the light comes on...that's why I'm so concerned b/c I literally just put $20.00 and I've only driven 42 miles and it's already on a quarter tank.........!!!!
    Lilburn
    Quote Originally Posted by drmcivicsi
    LOL^^^^^^^^^^^^
    eff you jerk.
    Newbie Photodude RBS's Avatar
    All Over U S A
    change the gas gauge or cluster . .
    Fah-Q
    nope!
    If your break light is constantly on and your e-brake is not engaged that usually means there has been a drop in hydraulic pressure and your breaks should be serviced. Maybe somebody could clarify that, because I could be wrong.
    or you could just simply add some DOT3 brake fluid to the reservour
    Your Moms Moderattor
    pleasant hill
    Civics just have some f u c k e d up fuel gauges, they go up and down especially when your on a hill, or do a sharp turn, my gauge will go from more than half to almost empty back up to half if I do a 30 degree turn going more than 20mph.
    i second that^
    Fah-Q
    Troof
    Athens/ATL
    Quote Originally Posted by theprofiteer
    It's because your bobber in the tank is loose. My Silverado used to do that.... the tank was aftermarket, 60 gallons, and was shaped like a coffin... long and relatively narrow.... the bobber was only at one end. When I would stop hard, I would watch the fuel gauge look like a damn metronome going F to E to F to E and finally settling... it was annoying as ****.
    And by the way, PWNAGE is paying $180 to fill said 60 gallon tank, and it being EMPTY about 4 days later.
    no pwnage is when you put $80 worth in a truck just to have it all gone about 150 miles later.
