Results 1 to 11 of 11
Thread: GM 5.3 Vortec Questions
    Woodstock
    Default GM 5.3 Vortec Questions
    Yeah I know this is an "Import" forum but hell I thought there has to be someone with ideas.
    So yes I drive an 01 GMC Sierra with the 5.3 Vortec 327. Two weeks ago I did a Sea Foam Job on it, and last week I changed the plugs (OEM Parts) and changed my oil. Also, my lifters were ticking and I did the old trick of dropping a quart of oil out of your pan, putting in a quart of ATF (Trans Fluid) and running it for 30 minutes at about 2 grand.
    Well, honestly the truck had much more pep to it and ran better and my ticking went away so that worked. But, my millage dropped significantly. I averaged 14 mpg on the highway. Now this is a stock truck, no lift, stock tires with exhaust work.
    I am leading towards EGR or O2 Sensor...
    Ideas? Thoughts?
    Reps will be given for help.
    Honda RC51 SP1
    Yoshi RS-3 Cans
    520 Conversion
    Clip Ons
    Race Tech Fork Kit
    \m/>_<\m/ dorin48's Avatar
    Canton
    Really it could be a number of things. I'm assuming that there is no CEL which makes things more of a headache. Try having it scanned for stored codes just for the sake of it, and not to be an ass but its a 325. 327's were from the 60's
    Toyota Tech
    Dec 2003
    Claxton, GA
    your supposed to change o2 sensors after seafoam, all the nasty that comes out of your engine builds up on them. that would be first guess
    Woodstock
    Hmm I never new you were supposed to change the O2 sensors after you run seafoam. Thanks.
    And damn I never knew it was a 325. I could have sworn I read it was a 327 but after sitting here and googling lots of junk, your right.
    Honda RC51 SP1
    Yoshi RS-3 Cans
    520 Conversion
    Clip Ons
    Race Tech Fork Kit
    Senior Member jfman's Avatar
    Did you know an ls1 bolts right into your truck.... Not sure it'll fix you mpg issue howerver
    AWD OH MY KPowerEP3's Avatar
    Ellenwood
    Quote Originally Posted by jfman
    the 5.3 is a gen3/4 motor, it's the same as an LS1, you can use LSx Heads, cams, etc.
    but, as said before my guess would be the o2 sensor, because I have heard stories of the chemicals in the smoke messing them up. Also, you could have loosened a chunk of carbon that got stuck in your EGR, and you can try to clean it.
    Woodstock
    Sweet. And hopefully if I get some money that can happen soon.
    But I guess its between the EGR or 02 Sensor. Honestly I have never cleaned out an EGR valve before. Is it quite simple? Just literally take it apart and clean it and put back together? Or do I need certain chemicals?
    Honda RC51 SP1
    Yoshi RS-3 Cans
    520 Conversion
    Clip Ons
    Race Tech Fork Kit
    Ellenwood
    Quote Originally Posted by Blitanicle99
    It's really easy, if there's anything holding it open, you'll be able to see it blocking the pin's movement. If there is use a toothpick or something to get the solids out, and give it a little carb/TB cleaner.
    Woodstock
    Deal Im gonna go get some carb cleaner and o2 sensors tonight and have some fun wrenching tomorrow
    Honda RC51 SP1
    Yoshi RS-3 Cans
    520 Conversion
    Clip Ons
    Race Tech Fork Kit
    Heckler Dietcoke's Avatar
    Richmond Hill, GA
    Seafoam destroys 02s.
    2011 Camero - Fast
    1998 T/A - Slow
