Results 1 to 8 of 8
Thread: bored engine
    1.5T AnTi-PooN's Avatar
    L'villE
    Default bored engine
    is it possible to bore a d series too much???? if so what would be safest
    middle ga
    yes you can bore it to much....i couldnt tell you what is safe..for f/i probably not more than 1mm over with out risking cracked sleevage..why not just sleeve it though?
    Quote Originally Posted by -SkInNy-
    **** yeah it is. I took this ***** ass D-16 to a cribbage meet one Tuesday evening and that mother****er sputtered and choked the whole mother****ing time we were there. So we left and I took it to see Lost in Translation. I've never seen an engine so ****ing bored in all my ****ing life. Later, QD.
    L'villE
    what is sleeved... i wanna completely build this new z6 to see how much n/a horse power i can get out of it just for fun
    middle ga
    you repace the factory sleeves with stronger ones. if you are staying n/a i would not really worry so much about it. it expensive anyways
    Newbie Photodude RBS's Avatar
    All Over U S A
    sleeving is always good, especially if your going to bore it out more than factory specs . . .
    i like hubcaps madwick's Avatar
    Dallas
    sleeving is when they remove your oem sleeves and install new ones.
    instead of seeing the gap between the sleeve and the block, they actually install a sleeve that allows you to go much higher
    in a b18c1 its a 81mm. i think you can go as far 87mm when sleeved to the max size.
    you'll have to buy a whole new bottom end and send your block off to a machine shop to re-sleeve it.
    i am going through this myself with my GS-R/CTR motor!!! not sure if its worth it on a D but go for it.
    Dallas
    check out this site
    http://www.customdesignperformance.c..._sleeving.html
    it shows you what they do from start to finish on a b series
    hope that helps!
