Results 1 to 16 of 16
Thread: charging problem on an ek with a b18b1 swap
    Default charging problem on an ek with a b18b1 swap
    I changed the alternator and battery and iam still having problem with the car not charging? When i remove the negative cable the car dies.. any info ..thanks in advance ...
    "big $hit poppin"
    in the slums where killas get hung
    is it possible that you have an electrical draw while the cars off? (ex. loose wires, poorly installed stereo)
    i took it to auto zone and it was shooting a p1298 code.. any ideal of what this may be???
    Quote Originally Posted by b18c5
    Electrical Load Detector Circuit High Voltage
    What's been recently done to the car? There may be a negative and positive reversed somewhere...
    well i change the o2 sensor with one off a obd1 motor ... what if water get on the motor ...
    uhh, did the connector work?
    yes it plug right up ... still cant find out what is wrong ... anyone with this problem before ...
    where is the ELD located ....
    boricua chrisdohck's Avatar
    that ob1 o2 sensor was it universal or did it already come wired and all u had to do is plug it up?
    OBD1 only had a primary while the OBD2's have a primary and secondary right?
    the one in the cat is the one i replaced ... i guess its the secondary ... where is the eld located ???
    It's not the ELD, it's that sensor. OBD1 sensors have 2 wires, OBD2 have 4...two being for the built-in sensor heater and that connection is being read as open thus causing the code.
    so it the sensor that is causing all this mess ... so that is causing the battery not to charge ...
    can't guarantee that but gotta start with what you do know and if that's a 2 wire O2 sensor then it can throw that code...
    Oct 2003
    FIRST, Check the fuse inside the car in the fuse panel for the alternator. <--that fuse being blown out will throw that code as well
    ELD is located on the underside of the main fuse box under the hood
    the fuse isnt blown but not reciveing any current .. and the o2 sensor have four wires ...
