Results 1 to 4 of 4
Thread: ECU for 89 CRX HF swap to 92-95 sohc vtec???
    AKAudioINC AKAudioINC's Avatar
    Carrollton/Kennesaw/Douglasville/Peachtree City
    Exclamation ECU for 89 CRX HF swap to 92-95 sohc vtec???
    :idb:I need to find an ECU for my 1989 CRX HF that will work with the 92-95 D15B 5spd VTEC I just bought as an alternative to the stock D15 non-VTEC... What should I do and where should I go? I need one cheap as possible! I also need a wiring harness, so any help will be grateful
    Cory Brooks
    AWD OH MY KPowerEP3's Avatar
    Ellenwood
    The ECU you need is a P28.
    Augusta, GA
    you should just convert to obd1, and just use a stock p28 ecu...
    Ellenwood
    Quote Originally Posted by b17a1db2
    Good call. I forgot the OBd1 conversion part. There's a website call the ZC resource that has some good info on converting obd-0 to OBD-1 as well as the wiring changes you need to make. Also, check out honda-tech, they're douchnozzles, but the site's full of good info.
