Results 1 to 9 of 9
Thread: 1990 honda civic no start!
    Default 1990 honda civic no start!
    i have a 1990 honda civic hatch it has a d15b1 and i try to start it but it wont
    i have replaced starter,ignition switch,main relay,batery,the whole distribuater and i look at all the fusese and they are all good. please some 1
    help me with this problem thanks............................
    Senior Member JDM onlyy's Avatar
    Jonesboro/Stockbridge
    Hmm..check your ecu, might have a bad one. Switch it out with another or something. Are you throwing a CEL? Does the engine turn over? Need more info on what its doing err what its not doing..Lol
    Default 1990 civic
    i can pop the clutch and it dose start the engine dose turn dosent make any funny nosie or anything it just dosent start....i bought 1 of the auto zone remote control starter but it dosent start though.. i look at the ecu and it flashes a red light when you turn yhe key 1 or 2 times but then it turns off my phone # is 678 226 1511 edgar
    Mountain man green91's Avatar
    Dahlonega, Ga
    so you can roll the car off? does it click at all when you try and start with the key?
    it makes a click sound when i turn the key.. but it wont start
    southside ATL
    probbly somthing simple like the battery terminals...probbly should put like a paper clip in between them(so that they are really touching)...cuz i kno that what happens to me..
    my 2 cents
    BABIES "R" US crew
    1.5T AnTi-PooN's Avatar
    L'villE
    replace positive battery cable maybe???? happened to me in same car wasn't getting enough power through cable even though the battery was fine.
    o.k guys before anything, thanks for the support from you all but i found out the problem it is in the clutch pedal, on the very top of the pedal there is a pointy small plastic
    that kinda engauge the clutch so that when you turn the key the car starts,and
    i put a screw on the hole and it works fine now so thank guys 4 the support
    Quote Originally Posted by JDM onlyy
    fuck we have the same user name...
