Ok here is the situation, I had a buddy of mine with a 97 DX hatch whos transmission went out, and also had a burnt ass clutch.
I sold him my EX transmission, and he bought a replacement clutch kit.
Keep this in mind his clutch was burnt bad, and his flywheel had some signs of overheating.
I know the transmission is good because I drove with it a while back, and it was perfect. No noise or grinds or problems of anykind
So I took everything off, replaced the Transmission, Clutch, Pressure plate, and throw out bearing. put everythign back together, filled the trans with 10w-30 and set for a test drive and I get hit with a problem
Heres how it goes:
When the peadal is depressed or when its in neutral there are no noises.
but when I put in first and begin to take off there is this very noticable rattling or chattering type of sound, its loudest in first and seems to go away as RPMs go up, then its a little quieter in second and goes away as the rpms go up, still a little noticable in 3rd but goes away as the RPMs go up, and by 4th or 5th gear I cant hear it anymore.
Keep in mind the flywheel was not resurfaced.
I need to pinpoint this problem, because I have to go back and take everything apart and try to figure out exactly what is causing this, but I do not want to go in blind.
Anyone have any suggestions or any way I can pinpoint the problem?
