Thread: Boosting problem
    Formerly Spyder Man
    Buford, Ga
    Default Boosting problem
    ok so i have a random problem in my 02 1.8T Jetta. when i start and then take it for a spin it hits 10-11psi then drops back to 9ish, which i assume is normal. when i drive the car for any distance it will randomly start to run only like 4-5 psi. there is no CEL. i can then turn off the ignition and start it again and all is well. i dont mean let it cool off or anything, often i do it as im driving down the road just click it off then back on real quick and suddenly its back to 10ish psi like nothing ever happened... i dont want to take it to a dealer but i may have to. i also dont want to get my ECU chipped if there is a problem that would be covered under my warranty.. any advise would be appreciated.
    :boobies:
    -=Mi4=-
    if not chipped then take it to the dealer. you are going on a hard limp. i am not sure what the requested boost is but when you over boost then it will hit limp. prolly your n75 is bad. prolly need a throttle alignment as well. that can be done with vag.
    old school fool Allstar3.8T's Avatar
    Loganville Ga
    I was thinkin N75 as well, Vag it, the go to ECStuning.com and get a race valve and be done!
    Greg
    86 Buick GN
    07 Passat Wagon
    01 Frontier
    ⎝⏠⏝⏠⎠ RandomGuy's Avatar
    no, you guys are wrong, the problem is obviously the radiator... And those 1.8T's have the whole jet-valve problem. Get an eliminator kit and you should be fine. I have done this many times in my jetta and can do it with my eyes closed. go to www.lemonparty.org for more details... yeah im bored and i cant sleep
    Formerly Spyder Man
    Buford, Ga
    Thanks everyone but RandomGuy
    :boobies:
