Results 1 to 14 of 14
Thread: i need help wit my 94 civic
    Default i need help wit my 94 civic
    ok my car wont start im trying to figure out wat the problem is im not getting spark to the plugs i changed the distributor and i still have the same problem one of my friends told me that i need to adjust the timing could someone please help me i dont know how to set the timing or if thats even the problem so if anyone could tell me wat the problem might be thank u
    02 WRX patrick4588's Avatar
    warner robins
    have you changed spark plugs and plug wires lately? try that
    Southside
    Here's one way to check. Jack up the driver side of the car and pull the front wheel off so that you can see the crank, I forgot the size of the bolt on the crank (but whatever size it might be) put the socket on the crank. Pull the spark plug out of Cylinder 1 and place a wire clothing hanger in it so that it's touching the top of the piston, pull your dizzy (distributor) out of the head, open the cover to make sure that it's on 1, by following the plug that you've just pulled out. Now go back to the crank (while keep eye-level on the wire) turn the crank counter-clockwise and watch for the wire to go down and when it comes back up to the point that you know it's about to go down stop, put everything back on.
    I know it's pretty long, but hey when you don't have the money at the time and have experience, do what you got to do.
    thank yall im going to try all that as far as the plugs and wires i changed them out and got new ones so im going to try wat jdm said thanks ill let yall know if it works
    ok i tried wat u guys told me but that didnt work so if anyone can give me more advise i would thankful
    your moms house
    do you have fuel getting to it?
    FUCK B&D COMMUNICATIONS!
    yeah the fuel pump works im just not getting spark to the plugs i changed the whole distributor but my friend told me that i needed to adjust the timing i did that just like jdm_ek4 told me to but still no spark
    Southside
    Is your battery any good , cause I had a similar prob back in the day, I did all that and it came out that my battery wasn't strong enough, try checking that.
    How did you check your spark?
    Hampton, Ga
    check your fuses
    superduper LLLLLLLLL
    bring it to "Vuong's Garage"
    he's an IA sponsor, and does quality work for the low
    wat fuses would cause that problem???
    HONDA RIDIN LOW BOY
    do you even have the block off plug to the fuel injectors on the wiring harness its located where resistor box are in older hondas
    1.5T AnTi-PooN's Avatar
    L'villE
    have you tryed to pop the clutch?????? if you do that and it cranks it eliminates alot of possible problems.
