Results 1 to 40 of 54
Thread: H22A Head on a F22B bottom end...It can be done??
    Kennesaw, GA
    Default H22A Head on a F22B bottom end...It can be done??
    Just curious if any of you honda techs (or anyone who might have done this before) have ever bolted up an H22A head to an F22B bottom end and what kind of results they got as far as power, reliability, and if so what all I might need as far as extra parts to make this swap possible. What im thinkin is it should all bolt up and i'll have somewhat of an H22 with a cast iron bottom end for boosting? NE and all feedback is welcome
    NIKON Squad member 01
    OF*C
    OEMFitment Crew Memeber 01
    I shave my legs... dartingd's Avatar
    on the bike
    www.cb7tuner.com is the place you need!
    PSN SN= dartingd
    Yup^^^^
    Quote Originally Posted by tehpr3chr
    victory is mine .::UNKNOWN::.'s Avatar
    jonesboro, ga
    if i am not mistaken it will fit but it is highly unstable you could go for thousands of miles with a good tune or you would go for a 150 miles with the same tune my word of advise is beware
    NO NWS
    JJSPEC Racing
    n/m...had me confused this early in the morning, im thinking of the accord f series motors
    -2001 Lexus IS300
    Belview Insane Asylum
    I think he is talking about the Accord F Series engines....
    JJSPEC Racing
    i thought there was a jdm f22 that was a dohc motor? but i couldve swore that f22b's were the 90-96 accord motors (and 98-0X are f23's?), shit what am i talking about i own an 01 accord, lemme go look...yea f23a1 in my 01 lx
    i hope hes not talking about the sohc motors, that shit wouldnt line up for hell, lol
    -2001 Lexus IS300
    There is an F22 that is a JDM DOHC engine, but it is kinda like the Civic ZC engine, DOHC but based on the D series. You can't bolt a B Series head on a ZC block.
    JJSPEC Racing
    interesting, i never really got into the dohc motors, i was a d series fan
    -2001 Lexus IS300
    Well I am thinking that F & H Series engines are the same. You can't put an H series engine on an F series block.
    Macon
    the only F-series engine that will safely accept the H22A head is the F20B from the accord SiR and the Euro R (before the H22A Euro R). It comes stock with the same head as the JDM Prelude type S H22A head. Any other F-Series engine will need some modifications (almost like doing a LS/VTEC conversion on a B series) but the F series engines will never rev high enough in stock form to take advantage of a H22A head, which makes the extra power mainly above 6k rpm. The F series can only safely go to about 6500 rpm stock on a daily basis. Now if you are building this as a race engine that you plan on running at the strip, then I say go for it, but if you want something reliable to use as a DD or something like that, then I say to just buy a new engine. If you want to keep it F series, get a jdm F20B engine (make sure to get the ECU as well). It has 200hp and a 8k RPM redline, DOHC VTEC, and the same head as the jdm H22A type S/Accord Euro R. It pulls like a H22A, with only slightly less torque. They are also usually cheaper than a H22A because nobody knows what it is. Beau Gotti on here had a F20B in his prelude. Im not sure if he is still around, but if you know him or can find him, ask him about the F20B.
    edit: another key advantage of the F20B is that it has iron sleeves, not FRM like the H22A, F20C, or C32A. FRM sleeves cannot be honed, bored, etc. You just have to get the engine resleeved. Iron sleeves can be bored or honed. B series engines have iron sleeves. You mentioned something about turboing the engine. FRM sleeves will only safely hold about 8psi or so. Iron sleeves will hold 12+psi.
    Land Rover LR3 HSE
    Great post and has every answer he could need for this. +14 to you.
    Kennesaw, GA
    pretty insightful post indeed:goojob: +1 for u sir
    OF*C
    murdahrin dem Blood-Claat!
    Great post as usual .
    I like hybrids if they are done right. For one... I wouldn't take a h22 head and slap it on a f22 bottom end just like that. I'd build the block and get h22 pistons. Better yet... the type S pistons. Reason being this combo that he is talking about still won't make as much power as a stock h22 because the compression isn't there. I'd also balance the crank so I would be able to rev atleast as high as a h22. But your way is much easier lol...
    To the orginal thread starter. It can be done. but it will cost you to do it right. it's been done before.
    tel.
    good info yo + for you sir
    Macon
    thanks
    Land Rover LR3 HSE
    Dunwoody/Sandy Springs
    ^+1. great post
    You can bolt an h series head on a single cam f series block. Look up G23, That has h23 head and f23/22 block. Check it out.
    Yeah but why?
    on the bike
    ^^^this is correct also...i would suggest and f22a or f22b block...if i'm not mistaken these engines were iron sleeved as well...they didn't rev high though, so you're still going to run into problems a bit unless you build the bottom end. like i stated before, go to www.cb7tuner.com/vbb for their forums and check their multiple frankenstein posts...do a search for f22a frankenstein, h22 frankenstein, or something like that...there's a couple of guys on there that have successfully done f22a and b blocks w/ h22 heads and managed to get in the 150s-160s whp i believe...for some reason i think i remember the number 147whp from one guy w/ an f22a block and h22 head...hope this helps some
    PSN SN= dartingd
    The Dark Lude dakilla4ever's Avatar
    In the Darkness
    Ok. where should I start. The F22B came in the JDM prelude Si. Honda produced the H23 for the american market. The F22B is basically the same thing as the h23, but it has 9.2-9.5:1 compression and an 85mm bore. unlike the h23 and h22 that have the 87mm bore. It also has Iron sleeves in it stock. Everything on it is interchangeable with the h23 so...... if you want to bolt an H22 head onto it all you have to do is follow the same procedures as if you were doing an H23VTEC build. Matter of fact here is all that you will need.
    write up... not sure but i do know all the parts required.
    h22a head 93+(USDM) or 92+ (JDM) with all internals and valve cover
    h22a thermostat housing
    h22a waterpipe
    h22a waterpump
    h22a headgasket
    h22a lower crank gear
    h22a timing belt
    h22a headbolts
    h22a plug wires
    h22a intake manifold (injectors perfered)
    h22a header and downpipe
    h22a cam gears
    h22a top timing belt covers
    h22a power steering braket (h23 doesn't line up right)
    everything else is easy.. swap out all the parts and sensors from the h23 to the h22a intake manifold.
    you can use the h23 powersteering holder but you ned to grind some off the mounting point to clear the head if not it won't bolt up, about 1 inch or so....
    eh.. keep the same distributor mounts the same and is fine, but the wires are deeper in the h22a. use the manual tensioner.
    replace all the parts listed above, rmove the oilcontrol plug in the block, before putting the head on.
    install all the parts, you will need to run other wires and the ecu, but machanically this is it, you cannot use the same waterpump, lower crank gear because the teeth are off and the belt would fail....
    anybody attemptin this from a h23 is waisting his time and money.. simpler to go if you allready have an h22a... otherwise will be more expensive the other way...
    my own opinion.
    and also you need to modify a couple vacuum lines and coolant lines if you keep the non vtec throttlebody because of the extra line.. otherwise do-able....
    hope this helps....
    As long as you balance the crank and install the H22 oil squirters in, it will last much longer than anybody will think and still be able to rev as high as a stock H22. Hell throw in some h22 type-S pistons and rebush the stock h23 rods and you'll have 11.6:1 compression with a 2156cc Vtec motor. Basically your planning on making a stroker kit out of stock parts. If you done this, me and you will be in a race to see who finishes there's first. If anyone doubts what I'm saying go here and work the numbers out yourself for extra confirmation:
    http://zealautowerks.com/hfseries.html
    Not only have I done the numbers but I've seen it done. Trust me it works as long as you do it right the first time. Good luck and have fun.
    Fast+Cheap= Not Reliable
    Cheap+Reliable=Not Fast
    Fast+Reliable=Not Cheap
    THE DARK LUDE SPEAKS
    Quote Originally Posted by dakilla4ever
    h22a waterpipe
    h22a waterpump
    h22a headgasket
    h22a timing belt
    h22a headbolts
    h22a plug wires
    h22a cam gears
    my own opinion.
    hope this helps....
    Wow! I see you've learned a lot these pass couple of years.
    tel
    Kennesaw, GA
    +1 to anyone who posted info on the subject. But i think Allmotor persuaded me to go a different route
    OF*C
    Macon
    Quote Originally Posted by blank cd
    If you decide to go with the F20B let me know. I would really like to see it in an accord. I was sooo close to getting a 98 accord ex 4 door (dont hate, 4 doors are cool too) and dropping a F20B in it, but I got a great deal on my GSR, so that will have to wait. Imagine a F20B with hotter cams, an accord euro R intake mani, and a good tune. It will rev higher than the H22A (shorter stroke!!!) and should be easier to persuade power from than a USDM H22A since the c/r is higher. I still have that on my list of honda's to build. It would definitely be different!
    Land Rover LR3 HSE
    Kennesaw, GA
    Well expect it pretty soon. Im thinking about gettin a loan or something. Im still waiting on a settlement from when i got in that car accident, but I think the F20B is definitly the way im going. And im gonna need all the help i can get when im putting this motor in too. :Goodjob:
    OF*C
    I personally wouldnt do it. But hey, he asked if it could be done. And It can, im sure you can use a vtec f series block and an h22 head, but why put so much effort into it? who knows.
    on the bike
    basically guys this all boils down to how cheap it can be done for...you can pick up a sohc f series for nothing and throw an h22 head on it...get about 150 at the wheels which isnt all that impressive, but it's a lot better than stock...
    PSN SN= dartingd
    his way is expensive too. Unless you get the f20b . but good luck getting the tranny with it. Also make sure you get the manual ecu. That ecu's fuel cut off it at 9k.
    Macon
    Quote Originally Posted by Ludester
    yea the auto tranny ecu makes 20hp less, but has more midrange torque. In other words, make sure to get the MANUAL ECU!!!!!!!!
    BTW the F20B will bolt up to any f series or H series tranny. I suggest a 4th gen jdm tranny with LSD, or a 5th gen jdm with LSD (The 4th gen are easier to find).
    Land Rover LR3 HSE
    v2.0 IndianStig's Avatar
    Sep 2004
    Gwinnett County
    F20B is the way to go. I once had plans to do a turbo F20B in my old CB7, those were the days.
    great choice . what year accord do you have?
    change the oil pump to a usdm prelude pump. I think that's pretty much the major change I can think of off the top of my head. everything else is little compared to that.
    Macon
    I didn't think there was a difference...
    Land Rover LR3 HSE
    Where is the crank sensor on the obd2 accords? Isn't it on the oil pump like the obd2 preludes? .
    Macon
    yea and his car is obdII, same as all F20B engines.
    Land Rover LR3 HSE
    so then he would have to change the oil pump becuase the f20b has a internal crank sensor. (internal meaning inside the dist.).
    Kennesaw, GA
    ...so apparently you guys are doin my engine swap for me
    OF*C
    hahaaha that depends on how much your paying. When I did my swap it took me like 8 months. Granted I didn't really know what I was doing. I learned a lot from it. I don't think i want to do it again lol...
    Macon
    yea how much $$$ is involved. Last swap I did took me about 2 weeks (weekends and a few evenings only)
    Land Rover LR3 HSE
    that's about right. I couldn't seem to figure out what I wanted to do the motor before I dropped it in. I kept changing my mind and what not. Then I couldn't find the tranny I wanted. It was stressful.
