Results 1 to 18 of 18
Thread: Does rim size affect the speed?
    Default Does rim size affect the speed?
    Ok. I have a 93 Civic Hatch and it originally can with 13's on it. Now I put some 15's and wanted to know if it affects is. Lets say im going 40 would it bump me up to 50?
    It's good to be boosted JennB's Avatar
    ITP
    Are you talking about the accuracy of your spedometer? if so yes. But not just the rim size, the overall diamiter of the entire wheel. You can get smaller rims and then put tires with a larger sidewall on them and barely effect the spedometer accuracy. But say you go to a smaller wheel and a lower profile tire (or larger, either way makes a difference) and yes.
    Put both of your tire sizes in this calculator to find out
    http://www.miata.net/garage/tirecalc.html
    2005 Mazdaspeed MX-5 -1.8L Turbo
    Tire Size Comparison
    Specification Sidewall Radius Diameter Circumference Revs/Mile Difference175/70-13 4.8in 11.3in 22.6in 71.1in 891 0.0%195/50-15 3.8in 11.3in 22.7in 71.2in 889 0.1%It gave me this explnain?
    Im French! Frög's Avatar
    AMERICA FUCK YEAH
    Quote Originally Posted by JennB
    side note, i saw you driving on spalding crossin holcomb bridge yesterday..
    Thanks for y'all help.
    It means that you can go to a 195/50-15 without affecting the speedometer. Later, QD.
    Thanks
    banned from heaven..
    if your car starts out with lets say 185's and you put 225's.. it'll fuck up your sppedometer. you think you're going 50 but you're only going 40mph... not sure about anything else. this situation happened to a firend of mine, awhile back.
    On The Grind.. Djlin's Avatar
    so if i have 17's im not really going the speed my speedo says?
    Use this http://www.miata.net/garage/tirecalc.html
    Quote Originally Posted by Djlin
    well this happend to an Altima. with wider tires... not sure about the Rim size.
    Here and there Hulud's Avatar
    Omnipresent
    this should be in the WHEELS section
    Val for President
    Omnipresent
    anyways heres a simple calculation that can help
    your tires WERE 175/70/13 and you went to 195/50/15
    so heres what you do, convert 175mm to inches (175 x 0.039) = 6.825inches
    then multiply your inches by 0.7 (the 70 shows that 70% of the width of the tire is the height of the sidewall) 6.825 x 0.7 = 4.7775
    then you multiply that by 2 and add the 13 inches for the rim and you get the wheel height. (4.7775 x 2) + 13 = 22.555
    so do the same for the new wheels and you want to be as close as possible.
    195 x 0.039 = 7.605
    7.605 x 0.5 = 3.8025
    (3.8025 x 2) + 15 =22.605
    so 22.555 compared to 22.605
    you went a little bigger by 0.05 inches, which means that your speedometer will say you are going slower than you actually are (but in this case i doubt it will be noticable)
    Val for President
    Ah, yes that explains everything.
    195 x 0.039 = 7.605
    Georgia Muscle twinj's Avatar
    Da "A" Niccuh
    My .02 arent needed.
    Acworth
    easier solution- go with the flow of traffic- not more not less.
    San antonio 210
    Quote Originally Posted by GSRteg
    no.. i have 15s and riding normal
    Got it.
