Results 1 to 5 of 5
Thread: B18B timing belt
    Default B18B timing belt
    If i want to run a GSR water pump on my LS motor, can i still use the LS timing belt?
    warner robins
    why not just use a ls water pump???
    JJSPEC.COM
    LS water pump=22 teeth, GSR=19 teeth which means at high RPMS, the LS is going to stop pushing water and start making bubbles, but with the gsr, it still continues to flow at a good rate
    woodstock, GA
    is there air in your coolant system? why would you be making bubbles
    www.wagenwerksatlanta.com
    Auto Collision & European Restoration
    920 Cripple Creek Drive
    Lawrenceville, Ga 30043
    678.407.8025
    you must use the SAME TIMING BELT as the WATER PUMP you are using.
