Results 1 to 6 of 6
Thread: HID HELP
    lube me up abdullah9018's Avatar
    ga
    Default HID HELP
    one of my hids is messing up whenever i turn it on it flickers then it turns off. i was wondering do i need a new bulb or is there something else the matter.
    **H.I.D KING** Nitro's Avatar
    STMN GA
    swap the bulbs and ballast & you'll be able to pinpoint the problem.......what kit is it?
    most of the time its just a loose pin in the harness....check those too & make sure there is a solid contact on all connections.
    Check your relay too. Chances are though its the Ignitor going out, but I could be wrong.
    white power!!!!!! .....1
    Belview Insane Asylum
    Sounds like a Ballast issue.
    ^+1
    Big Boss kennyboi's Avatar
    GA (somewhere)
    not really sure but run a relay kit if its a kit that came off a factory car.
    ----KENNYBOI----
