Results 1 to 10 of 10
Thread: s-13 problems
    In the land of the slow cars
    Default s-13 problems
    I am having a few problems with my '93 hatch. The lug nuts will not stay on, and it constantly runs hot. Have a new thermostat that will hopefully fix the problem. already put a new radiator in it so if anyone knows where I can get a cheap dohc ka water pump let me know. thanx
    Hampton, Ga
    replace your wheel studs and you probally have a air bubble in your cooling system
    I replaced all 16 studs, someone told me it could be the wheels but the guy that had the car before me said that he never had any issues. how do I fix the air bubble problem? drain it and refill?
    Sep 2003
    Powder Springs, GA, 30127
    Get some lock washers for you r e lugs. The air bubbles are harder, gotta catcht them when they expand, get some rug doctor foam eliminator, that generally does it.
    E
    Augusta, GA
    Are the wheel studs actually firmly seated in the hubs? Make sure they're not loose. If they are, replace the worn part (either the studs or the hub itself may be screwed up). Also, make sure you're torquing down the lug nuts enough. Might want to invest in a torque wrench if you haven't already.
    As far as the air bubbles....there is a bleeder screw....I think on the KA it's on the passenger side of the head, near the thermostat housing (someone correct me if I'm wrong...haven't lloked hard at a KA in a while). You will need to open that screw when the engine is cold, and run it for a little bit. You will need to repeat the process a few times (always waiting until the shit has cooled down before opening that screw again!).
    Also, make sure your thermostat is actually opening (sometimes a new one can be bad).
    ok so open the screw, let it warm up, tighten the screw and let it cool, open it again and do it all over.....? How do I know when its good..
    Augusta, GA
    Quote Originally Posted by 180inprogres
    When it stops overheating! LOL! Sorry, that's about the only way to tell for sure.
    turn the engine on but dont let it warm up because you will need to take that screw off , and wait till coolant starts shooting out...then you will have to cap it back on real fast.....
    so follow these steps i guess
    1) turn car on
    2) take screw off
    3) wait till coolant shoots out
    4) put screw back on
    stud problem i cant help you with...my stud broke inside my hub the other day with the lug still on it...what a day that was
    Well I used to break them every day
    Got really good at replacing them in under 10 minutes. Should've joined a pit crew. Thanx for everything
    ha, no, its cool, what a dumb question.....
