Results 1 to 3 of 3
Thread: Dual-Point to Multi-Point ??'s About Injectors
    Augusta, GA
    Default Dual-Point to Multi-Point ??'s About Injectors
    I've seen this done before, and I've seen it running..But I don't fully understand everything about it. It's probably simple..Anyway:
    I've seen OBD1 Injectors and Clips on a OBD0 Civic DX Hatch without the use of the resistor box. Is this all has to be done, just use OBD1 Injectors, and wire them in as normal when coverting to MPFI, and just don't worry about the resistor box? hmm. I need to know...Thanks alot..
    IA Juinor Member Mr_S13®'s Avatar
    Cumming, Ga
    you can if you convert the car to obd-1, ie. get an obd-1 ecu and a conversion harness...and distrubitor adaptor. But the easiest way is to get a resister box and wire it up like it comes from the factory. Good luck, and your best resource is the search function on honda-tech.com
    [SIGPIC]
    Augusta, GA
    thanks. i appreciate it.
