has anyone heard of a VG30DETT swap into a 240. im thinking of doing it but not alot of info on it. any advise:boobies:
it's been done, but they say its very difficult, check out this website to see what they say about it
http://klohiq.tripod.com/cars/240sx/swap.html
Coming Back...................................
Supraforums.com
G/L man, if you get it done, i'd love to see that. i've heard of people doing it; but i've never actually seen one done.
lolol, have you ever worked on a VG30DETT? (or even a VG30DE)
All I can say is dont do it...lol...9/10 swaps attempted never run.
No Homo.
lol my ex g/f altima had a VG30de
i don't think soOriginally Posted by §treet_§peed
...j30's had a tuned down version of the VG30de's but altimas are front wheel drive.
dude i shit you not... even when she took it up to the dealership to see if it rly was.. no shit
a FWD VG30DE 3.0 liter V-6???Originally Posted by §treet_§peed
Your better off with a rb25 or 20. If u got big bucks then 2j is the way.
Originally Posted by GIXXERDK
Stay away from them unless you absolutely have to have one (a 300). I have a pretty large engine bay and to do ANYTHING beside intake or something siple you have to pull the engine. I would not even attempt it. Just 2JZOriginally Posted by speedminded
dont waste your money if you cant do it yourself. so many other alternatives that will achieve better results. 2jz is my choice.
yeah no shit.. thaqt's what i was like when i first saw itOriginally Posted by speedminded
They had KA24's at one time transversely mounted but i'm pretty sure never a VG30DE. Didn't they go from the 2.4L to a 3.5?Originally Posted by §treet_§peed
you idiots. Older Altimas had a KA24DE. Maximas had VG30E and later/newer altimas had the VQ35. J30 had a VG30DE.
VG30ET>VG30DETT as far as maintenance.
02' Miata
The older Z31 VG30ET was pretty easy to work on. That in a 240 would probably be pretty good as i have seen those motors make 300-400hp on stock internals and 500+ on a built car. You can stroke it to a 3.3L too... thats a nasty motorOriginally Posted by NSCredondo
02' Miata
That's what i saidOriginally Posted by DropTopDrifter
you failed to mention that it was the MAXIMA that was the FWD VG30......
My post was more informative![]()
02' Miata
It's not a DE so it didn't matterOriginally Posted by DropTopDrifter
Plus V6 & v8 FWD's are the most ridiculous thing ever invented.
Ahhh, but there was a VG30DE in the Maxima.....
02' Miata
nopeOriginally Posted by DropTopDrifter
VG30DE
1990–1996 Nissan 300ZX
1987–1999 Nissan Fairlady Z
1988 Nissan 200zx (similar chassis to the 300zx, different panels
1993–1998 Infiniti J30 and Nissan Leopard J. Ferie
1992–1995 Nissan Gloria and Cedric
1989–1991 Nissan Cima
VG30E
1984–1989 Nissan 300ZX/Nissan Fairlady Z
1987–1988 Nissan 200SX SE
1984–1994 Nissan Maxima
1990–1991 Infiniti M30/Nissan Leopard
1990–1996 Hardbody Truck
1990–1995 Nissan Pathfinder/Nissan Terrano
1992–1999 Nissan Gloria/Nissan Cedric (179 hp)
1992–1995 Nissan Quest/Mercury Villager (modified to become a non-interference design)
Excuse me, the Maxima DID have a 3.0L with a dual cam head....
The VE engine is a 3.0 L V6 piston engine from Nissan. It is based on the Nissan VG engine and was only used for the '92, '93, and '94 model years. This engine has an iron block, aluminum cylinder heads with 4 valves per cylinder and dual overhead camshafts, variable valve timing on the intake camshafts, coil on plug ignition, and an available variable intake manifold. (5spd only)
A major difference between the VE30DE and the VG30DE engine is the heads. The low underhood clearance on the 1992–1994 Maxima demanded a special head to be developed with 30°, rather than 46°, between the valves. Lack of space also demanded a redesigned camshaft drive system, so a special chain drive was developed. The engine is otherwise similar to the VG30DE.
The 3.0 L (2960 cc) VE30DE produces 190 hp (142 kW) at 5600rpm and 190 ft.lbf (258 Nm) at 4000rpm. This engine redlines at 6500rpm. It was built from July, 1991 through March, 1994.
It is used in the following vehicle:
* 1992-1994 Nissan Maxima SE
02' Miata
Doesn't matter if it was a quad cam, rotary, or a radial....it didn't have a VG30DE, it was a VG30E & VE30DEOriginally Posted by DropTopDrifter
oohhh.. the block was the same, just had different heads
VE V-6 DOHC
4 Valves per cylinder
Variable timing control
3.0L Aluminum/
Iron Direct Ignition 1992-1994
Maxima SE
190/190 Similar block to VG series.
A lame duck engine, at least in the States.
Used only for three years in the Maxima SE.
Variable intake runners and (problematic but fixed in 94).
variable timing control.
02' Miata
my '90 Z32 VG30DE had variable timing...a year before VTEC!!Originally Posted by DropTopDrifter
whoops it was a Maxima lol Pwn my self on that one lol
vg something lol prolly the vg30e
