Thread: Might have killed the ZE
    Zoom Zoom kfzemx3's Avatar
    atlanta
    Default Might have killed the ZE
    I've been having some problems with overheating well i finally figured out it was blockage in the heater core. Well yesterday as i was checking coolant levels to make sure everything was ok, i pull my dip stick and relise i'm somewhat low on oil. But considering its about time to change the oil i didnt think nothing to big about it, and just added a little to it.
    Well today I run to work to grab my check before i head to class, and i hear the typically HLA noise from no oil at startup, which usually it goes away after a few mins. Well i get to work and start the car up after grabbing my check and the noise is still there. Got home and checked the oil and its BONE DRY. well i go and look where i parked the car the night before (3 roomates so i dont always park in the same place), and well there is a nice big oil puddle.
    I sprayed the engine down cleaned all the oil from the lower half of the car so i can try and detect where its leaking oil, and i fill the car back up with oil and and crank it up to build up the pressure, well it starts to drip drip drip, and i start looking around and notice its coming from above teh power steering pump. I notice smoke coming off the exhaust from where oil is on it.
    I started feeling around and sure enough i feel something like a jagged edge on the part of the head where it should be nice and smooth, i pull my hand back and its got a nice buildup of oil on it.
    So in short I think I may have a cracked head, pulling the IM tomarrow and i'm hoping that its just a bad seal and maybe the jagged edge i felt is a casting mark.
    I'll keep people posted
    I spend money on HP not Brand Names.
    08 Infiniti G37s 6MT [The Daily Beast]
    05 Mitsubishi Lancer Evo VIII MR [Sold]
    01 Lexus Is300 [Under Construction]
    93 mazda Mx-3 SE 2.5 Klze [Sold]
    92 mazda mx-3 GS 2.0 Kfze [I Killed it]
    ಠ_ಠ Kamikaze's Avatar
    Fulton Co.
    Hope it's nothing too serious.
    atlanta
    I'm still hopeful that thats not it, but i'm just sorta betting on the worse
    Cruzan Boy Siverprobegt's Avatar
    ga/VI BREED
    i can sell u some klze heads if u need them,let me know....Where you live at???
    92 mx3
    atlanta
    i live just south of norcross in chamblee
    Isolated Twinturbo6's Avatar
    Savannah
    Hell I have a whole probe with the entire ze engine in it, no miles since swapped... I need to get rid of. Needs tlc, and a front bumper.
    atlanta
    the motor is ok though if you have a turbo manifold
    ga/VI BREED
    Quote Originally Posted by kfzemx3
    EBAY
    92 mx3
    atlanta
    yea i know, i'm waiting for the next one that has the manifold, hotpipes, cold pipes, intercooler setup, it will fit on teh mx3 we just have to cut and weld the cross member to fit the pipes, then modify the the cold pipes a little, not to hard though
