Results 1 to 7 of 7
Thread: Ford Mustang Comp Cams XE 262 and beehive valve springs
    BLK96GT
    Lawrenceville, GA
    Cool Ford Mustang Comp Cams XE 262 and beehive valve springs
    UP FOR BUY IT NOW ON A PAIR OF CAMS FOR A 99-04 MUSTANG GT, AND A SET OF BRAND NEW BEEHIVE VALVE SPRINGS. THESE CAMS ARE BRAND NEW NEVER INSTALLED THEY COME WITH CAM CARDS AND ALL INSTRUCTIONS TO INSTALL. THE PART # ON THESE CAMS IS 102500. THE LIFT IS .545 INT AND .545 EXH THE DURATION IS 226 INT AND 230 EXH @ .050
    BRAND NEW IN THE BOX COMP CAMS SOHC 4.6 2 VALVE MUSTANG VALVE SPRINGS 1994-2004.
    Ford 4.6L Engineered specifically for Ford modular engines. These springs are made of a high tensile, super clean, chrome silicone material. Designed to work with cams up to 0.550'' lift, and fits in the stock pocket without any machining. Great for the Xtreme Energy Cam series. Uses stock retainers.
    Valve springs that won't crack under pressure.
    Valve springs are one of the most critical and overlooked components in your engine. They must be matched to your cam in order for the engine to reach its full potential. It does absolutely no good to install a cam that will rpm to 8,000 if you do not have the correct springs. Use only the valve springs that will give the recommended spring pressure with the valve both on the seat and at maximum lift. Comp Cams valve springs are offered in single and dual styles to meet their cam requirements.
    Number of Springs Per Valve: Single
    Outside Diameter of Outer Spring (in): .959
    Coil Bind Height (in): .952
    Damper Spring Included: No
    Spring Rate (lbs/in): 191
    Inside Diameter of Outer Spring (in): .636
    Inside Diameter of Inner Spring (in): .636
    Valve Spring Style: Beehive
    Coated: No
    Quantity: Sold as a set of 16.
    Attached Thumbnails Attached Thumbnails -c3db_1-jpg   -4_6spring-jpg   -c409_1-jpg
    S281 soul's Avatar
    Gtown
    price?
    Its just a bodykit
    BLK96GT
    Lawrenceville, GA
    i will sell them for 675 and they are brand new never been used
    BLK96GT
    Lawrenceville, GA
    i have decided to drop the price on them to 600 if ayone is interested. i need to sell them. ASAP
    Hiawassee, GA
    PM straigh6, he was looking for these for when he does his PI swap.
    -Zach-
    1987 Toyota Pickup - Toy
    BLK96GT
    Lawrenceville, GA
    i tried looking for him and couldnd find him. if you know him tell him to come on and let me know if he is interested in buying them
    Hiawassee, GA
    Ahh might help it if spelt it right. straight6 is his s/n. My bad bro.
    -Zach-
