Results 1 to 35 of 35
Thread: 3/4 of Swap Done: Need help ASAP
    EF Squad
    Default 3/4 of Swap Done: Need help ASAP
    Hey last week i got someone to take out the d series and now have already put the b20b into the crx. However, there is a problem that has been encountered and he believes it could be wiring from dpfi to mpfi. The car starts when there is a starter fluid was used BUT only for a few seconds and then shuts off. And since he is going out of town on Friday (Jan. 2) and really has no ideas on what could of cause the car not to start I would like one of the EF squad members to help me out if possible and willing to drive up to my place (Not driveable since wouldnt start) and figure it out. There will be a fee on my side if have to.
    As for the wiring parts he didnt cut any wires only splice it so it wouldnt really be a problem if anyone has to do the wiring over.
    Here is the info about the car that i think will be handy:
    -91 crx dx
    -Motor : b20b
    -Tranny:b17
    -Intake Manifold: LS b18b1
    -OBD1 LS ecu
    -OBD2 LS distributor
    -OBD0 to OBD1 ECU Conversion Harness from Rywire
    Here is my contact number: 404 933 9926.
    Augusta, GA
    good luck, i would give it a shot, if i was closer.
    EF Squad
    hehe thxs man. Yea i know u would definately help... too bad u live like 2 hrs away hahah.
    Southside of The Jungle
    sounds like your not getting fuel if it starts with start fluid.Check to see if you hear the fuel pump when you turn the key.If your fuel pump is working then he might have did the injectors wrong.The way I checked mine was take them out while on the fuel rail disconnect the dizzy and turn the key for a second.Make sure u put the injectors against some cardboard.If your injectors are wired right then you should notice on the cardboard.Some fuel should be a even spray across.
    EF Squad
    yea I hear the fuel pump when i start the car. And i doubt its fuel pump because my car starts fine when i had th d series motor in. I not exactly sure if its the injectors because he said he tried replacing an obd0 injectors and then with obd2 injectors and still dosent work.
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    which conversion harness did you use?
    EF Squad
    obd0 to obd1 conversion harness from rywire.
    Hamilton, GA
    Same thing is happening to my buddies hatch with a b20 and he still hasn't figured it out
    Southside
    Quote Originally Posted by T2KU
    Damn
    IA Member blumagic04's Avatar
    somewhere
    I just had a car in the shop with the same problem, the first thing to do is check and see if fuel is getting to the engine, then check and see if fuel is comming out the injecters, it sounds like you have bad fuel injecters, another question is the check engine light on.....
    2004 SONIC BLUE GT MUSTANG
    Dropped
    .8000K HIDS.
    .FLOWMASTER EXHUAST.
    .K&N.
    EF Squad
    Quote Originally Posted by blumagic04
    No surprisingly no check engine light on lol.
    Your friend did the wiring for the harness right?
    Bring it to us, we can fix it 678-567-9384
    EF Squad
    I wish i can but i cant drive teh car and paying for tow is too much.
    Your mom's bed
    CHECK THE VACUM LINES ASWELL AS THE INJECTORS. SOMETIMES IT'S SOMETHING SIMPLE.
    somewhere
    Where do u live maybe I can come and help
    Dropped
    .8000K HIDS.
    .K&N.
    EF Squad
    I live in lilburn up In gwinnett county. But the car isn't at my house yet. The person doing the swap for me is getting it towed to my house today because he is going out of town today. And the place he was doing the swap at is his friend's garage.
    Most likely if u guys can help is during this weekend.
    somewhere
    Yeah I stay in lawrenceville so I'm close so I will be able to help you out.
    So send me a message when you have the car at ya house.
    Dropped
    .8000K HIDS.
    .K&N.
    EF Squad
    Alrite thxs alot man. U got a crx as well too?
    Quote Originally Posted by Tensa_Zanget
    Check to see if the injectors are spraying it could be wiring that is keeping them from spraying.Doesnt have to be the injectors themselves could be wiring that isnt getting the signal to them.
    Hamilton, GA
    My friend from the other post I made was gettin fuel all the way to the injectors but nothing was comin out so he replaced the injectors and it did the same thing
    EF Squad
    Have he ever got it figured out yet?
    Did he check his fuel filter and fuel rail my brothers ef was like that after the filter was clogged it wouldnt start and no fuelage coming out 2 injectors DPFI FTL!
    somewhere
    naw i dont have a crx but I do work on cars and a couple of my friends have crx and hatches, so has the car made it to your house yet....
    Dropped
    .8000K HIDS.
    .K&N.
    EF Squad
    nope not yet.
    EF Squad
    What kind of crx swaps ur friend have done and wat kind of obd?
    Hamilton, GA
    I'm pretty sure he has checked everything. He knows his Honda's pretty well. I haven't talked to him lately so I don't know if he fixed it yet. He also is a workaholic so he doesn't work on it regularly
    EF Squad
    up
    EF Squad
    Come on EF squads i really need help.
    EF Squad
    far far away
    With the information you've provided, we can't help you. All I can say is verify that the wiring is correct.
    EF Squad
    Quote Originally Posted by jfrolang
    That's why i said if possible somone can come up to my place and check out what could be the problem. There will be a fee on my side if it has something to do with wirings and require the person to re-wire it.
    ECEFC.com
    Sorry I can't be any help this week. If you dont have it fix by next week, I'll make arrangements with you.
    1.5T AnTi-PooN's Avatar
    L'villE
    who is the guy doing the swap?
    EF Squad
    the guy that did the swap named is Mario goes by Diego.
