Results 1 to 10 of 10
Thread: mini me info....
    building the new ef revized_DX's Avatar
    northeast ga
    Default mini me info....
    this is just a thought and may become a reality...can i do a mini me with a d15b2 block? what head is best and does anyone have info or write up to get this done usint this block? not online too much any more and i see im not BANNED anymore....ha ha..but would appreciate info on this...will look back daily for this info if yall can help....
    thanks alot!
    marc
    San Diego, CA
    Yes, I'm pretty sure so. Re-wire your car for MPFI. ZC pistons. Y8 Head, intake manifold, and exhaust manifold, and...I wanna say it's a Y8 ECU...
    Hope that helps...
    JDMadness ==> EvasiveEF9
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    as long as that is not the 8 valve motor your good
    San Diego, CA
    16 valve SOHC VTEC motor. From...don't quote me...96-00?
    70hp FTL StraightSix's Avatar
    Central, SC
    Any D-series block will do. Which head you choose will alter the compression ratio and what not. Google Compression calculator for some ideas.
    You'll want to use a P28 ecu, though. OBD-1 and has the most tuning options, oh, and either a D16Z6 or D16Y8 head.
    San Diego, CA
    *cough* Y8 *cough*
    1.5T AnTi-PooN's Avatar
    L'villE
    y8 v-tech would be borderline cool
    northeast ga
    Quote Originally Posted by EvasiveEF9
    *cough* Y8 *cough*
    i hear ya ben! so...anyone got a z6 or y8 head? im looking so i know this is the first place i should look...sorry been so long, alot going on! anyone with a head i would appreciate it....hit me up and let me know but correct me if im wrong but i need to do the harness ecu and distributor as well correct? maybe running a stock block for the moment but will be going through with this soon! might be making a move to the north side of the usa here soon but not sure
    Norfolk, VA
    eBay, ftw
    <---Click it.
    Central, SC
    It's a good idea to get the dizzy that goes with the head. If you go y8, Rywire sells an obd0 -> obd2 dizzy adapter. You don't really HAVE to get the wiring harness, but it could be very helpful.
