Results 1 to 40 of 67
Thread: Valve cover clean up
    JZX FTW!!! dtmcnamara's Avatar
    Dacula GA
    Default Valve cover clean up
    Ok so my valve cover was looking a little beat up after 8 years of oil changes, valve adjustments and just wear and tear on it. I decided to do a little DIY wrinkle paint and figured I would take a few pictures of it while I was doing it and do a little write up.
    Things you need:
    VHT Wrinkle paint (comes in black and red)
    Air Craft stripper
    Nuts and bolts
    Old shirt or towel
    First things first you need to get the valve cover off.
    Next you need to remove any rubber grommets from the cover
    Then you need to start to strip all the paint off the cover. What I did was cut up an old shirt and cover up the spark plug holes since the seals were still in. I sprayed the entire cover and let it sit for around 30 minutes while it did its magic. I then sprayed everything off and then sprayed the stripper where it was needed
    Once it is cleaned up you need to scuff up the bare metal. I used the metal scuffing pads and just cleaned everything up for about 10-15 minutes. This helps get any remaining paint off the cover and makes the surface easier for the paint to stick too.
    Finally you need to clean the cover one last time and dry it completely off.
    Next you need to cover up any holes in the cover. What I used were random bolts and washers to cover mounting holes, fill holes, and the sensor holes. This seems to work well. I then used the cut up shirt to cover up the spark plug holes as again.
    Now its time to paint. What I did was spray the cover with 3 thick coats. When reading the can it says to spray vertical, horizontal, and then diagonal, so I did. In between each spray I let the paint set up for 10 minutes.
    Once the final coat was put on I set the over to 200 degrees and the timer for one hour. I placed the cover on a tray with tin foil on it and place it in the over.
    Within 10 minutes you will see the paint start to wrinkle. Let the cover completely bake and thhen remove it and let it cool off.
    Once its cooled off reassemble the seals and then re install.
    If you have any questions let me know. I will be doing another cover later this month with the engine paint so I will post up pics of that once it is done.
    good job on the vc i ve done a few this way
    www.jjspec.com Macon, Ga
    Looks good!
    Middle, Ga
    I actually wasn't expecting it to look that good, man. Looks very good though.
    "Damn, Its Tyler"
    RaceReadyDevelopments
    paint booth
    so if you used wrinkle paint, why did you put it in the oven? was that just to bake it on or did the heat cause it to wrinkle more? i tried so kind of wrinkle paint before and it looked nothing like your's.
    Dacula GA
    the bake in the oven was to cure the paint. it was either an hour in the over or 48 hours in the air.
    paint booth
    ok that makes since.
    Ap2
    damn that shit looks hot!!!....shouldn't have done the spark plug cover though..just my 2 cents....
    where do you get that paint??..planning to paint my h22 valve cover red
    Project RB.
    Dacula GA
    auto zone and advanced both carry it along with a bunch of other parts store.
    I wasnt going to do the spark plug cover but then it was going to be a different shade of black. I plan on stripping the Honda symbol and the DOHC and VTEC like it was OEM, just havent done it yet
    Ap2
    cool, thanks man...i'm already stripping my valve cover.....do you know where to get the wrinkle red paint??
    Project RB.
    I did mine about a year ago and its still holding up. However I didnt bother stripping the paint. I just sanded it.
    looks hella nice man.
    Ap2
    i've been looking for red wrinkle paint...anybody know where i can get it?...i checked advance auto...pep boys..walmart...
    Project RB.
    Summit has it and I believe pep boys does too
    IA Member ap1tuner's Avatar
    rome, georgia
    bad ass job man. that looks really clean!
    DEVOTION... free with each HONDA
    clayton county
    hey good shit. + for the oven. =P
    I give out reps....
    Cute.
    who knows.
    very nice reps
    Team Korupshun DamnDisLaOsBoY's Avatar
    Lawrenceville, Ga
    nice shit david. looks pretty good all black!
    BOOB koukis14's Avatar
    Pennsyltucky
    Looks good
    VTEC Killa!! 99' LuDe's Avatar
    Warner Robins,GA
    used the wrinkle red on my mugen vc turned out nice
    1999 bb6 rip 1998 dc2 sold 2003 ep3 totaled 1999 em1 ftw
    MothBalls+GasTank=Faster sk8er602's Avatar
    Athens, Ga
    Came out looking good, I'm going to have to do this.
    Certified Gearhead 91boostdgsr's Avatar
    Jul 2009
    Griffin, GA
    currently working on mine to try and get it back red
    INSERT SIG HERE>>>____________________________
    DA9 lude66's Avatar
    south side
    mine is getting baked pic's up soon reps for write up
    DA9 lude66's Avatar
    south side
    Kennesaw, GA
    Someone carries blue spray as well. I think Krylon does
    NIKON Squad member 01
    OF*C
    OEMFitment Crew Memeber 01
    Jun 2009
    Phenix City, Alabama
    just wondering where can u get some wrinkle paint and about how much will it cost ?
    Dacula GA
    it was around $14 at autozone and/or advance auto parts
    DA9 lude66's Avatar
    south side
    Quote Originally Posted by dtmcnamara
    x2
    Exit 47 member #1
    Somewhere in tha south
    what temp do u put it on in the oven to bake?
    Dec 2008
    Looks good and nice write up by the way!
    Dacula GA
    Quote Originally Posted by mezzies96teg
    200
    Kennesaw, GA
    So are you just putting it in the oven to crinkle it more? Or do the directions require this? Just saying cause I cook alot and Id rather not have my NY Strip with a peppercorn and garlic crust taste like essence of Krylon
    OF*C
    Dec 2008
    It does leave a residue inside the oven! We clean our curing oven walls every week and you wont believe the crap that is on there. But just one valve cover wont be to bad but I still don't suggest doing it in the kitchen oven. Make sure you get all the oil out of the valve cover or it will really stink up the house and oven. Also if you have a wife make sure she does not find out .
    Senior Member Schugg's Avatar
    i like the all black, may have to do that to my valve cover, thanks for posting this
    - 1993 Honda Civic VX
    - 2008 Acura TL-S
    earth ????
    nice i did mine :-p
    GWINNETT IS GREAT!
    i actually do not like it like that...it should have been left with that metallic look...polish it shiny....it would look really nice...
    its just me..i like chrome valve covers next to the stock look
    Rome, GA
    awesome job man, looks real good.
    hmm so it IS ok to put it in the same oven that you cook in?
    Dacula GA
    Quote Originally Posted by Sammich View Post
    no mutations here yet...lol
    Just wipe the oven down after use. you will get most of the resin out of it.
