Page 3 of 6 FirstFirst 123456 LastLast
Results 81 to 120 of 234
Thread: General Tech, lolol
  1. #81
    Certified Gearhead jfryer496's Avatar
    Feb 2010
    Phenix City, alabama
    give me some gestimates! lol transmission experts gave me quote of 350
  2. #82
    Columbus
    me has problemo senors ok......car sometimes drives fine idles fine everything then ill notice increase in temperature and idle goes up which it randomly picks times to do it ive replaced the thermostat in it so far and when it idles up ill tap the IACV and it goes down im sure its needs to be replaced too any other suggestions?
    Little Talon That Could...
  3. #83
    theredneck JDMTEG1990's Avatar
    Nov 2009
    Phenix City
    just clean that damn thing prolly clogged and aint letting fluid through which raises temp and rpmm.. soap and water and let it dry out..
    i<3 MY BSERIES
  4. #84
    Certified Gearhead snowflake09's Avatar
    Sep 2008
    San Angelo, TX
    Quote Originally Posted by JDMTEG1990 View Post
    This...
  5. #85
    Columbus
  6. #86
    Boooosted!! kr3w108's Avatar
    Oct 2008
    Bama
    Quote Originally Posted by harleyweise View Post
    yeah ^ what he said
    Best ET 9.69@147 running out of gear....
    video of pass....
    https://youtu.be/Y4ogpwzNpzg
  7. #87
    Sep 2008
    San Angelo, TX
    yeah ^ what he said
    Lolol Yesssir. Now get on them abs son!
  8. #88
    Columbus
    you get on yours ive been on mine p.s and maybe your pull ups too
  9. #89
    Sep 2008
    San Angelo, TX
    Ahahahaha Thats a low blow right there.....lol
  10. #90
    Columbus
    saaaaweeeeeeeeeeeeee
  11. #91
    Sep 2008
    San Angelo, TX
    Lolol Trade me dude......
  12. #92
    Angry
    Might as well give this a shot!
    My car nissan 240sx hatchback I need a way to get it tuned without fouling the plugs every few hours.
    setup is aem fic,550cc,t28/t3 hybrid, walbro, damn car has no obd port because of the wiring harness I had to use to replace the old shitty one. I have a wide band car sits at about 12:1 at idle on average with all stock settings. When I try and lean it out it skips on accel no smooth transition, and jumps to 18:1 wtf
  13. #93
    Oct 2008
    Bama
    man fuck you dude!!....
    Quote Originally Posted by snowflake09 View Post
    video of pass....
  14. #94
    Sep 2008
    San Angelo, TX
    Quote Originally Posted by kr3w108 View Post
    Hahahaha
  15. #95
    Mar 2010
    alright so i went to crank my hatch and its not turning over. the battery has full charge and the starter is good. i just did a tune up so thats not it. i think it might be the neutral safety switch??? what do yall think? any ideas?
  16. #96
    Yea I drive a Neon! justnprsh07's Avatar
    Aug 2009
    columbus
    Jump it at the starter if it cranks it is prob neu safety, starter solenoid, or ignition switch
  17. #97
    whispering eye lover 1d10t's Avatar
    Columbus
    Could also be a main relay
  18. #98
    Hwy 315
    Quote Originally Posted by 1d10t View Post
    the engine would turn over if his relay was bad - just wouldn't start.
    Quote Originally Posted by egsn-95 View Post
    Double check and make sure your starter solenoid wire is attached - when the clip starts to wear out they tend to fall off from time-to-time.
    -jonathan
    [/URL]
    Jesus Christ is my Savior
  19. #99
    Feb 2010
    anybody know hwo to get the maintence light off on a 94 tteg ls? i done changed my oil hgaha
  20. #100
    Aug 2009
    columbus
    Figure out what code its throwimg and go from there
  21. #101
    Feb 2010
    so the maintence light throws a code too? any way to check it? i kno on my eg i had the plug was under the glovebox and ya had to jump the two things and the CEL would blink. how do you check the code on the maintence light? thanks!!
  22. #102
    cookie monster SAVAGE21PRO's Avatar
    phenix city,al
    you dont to reset the maint lamp key off - there is a button under the dash - press the button and hold switch the key on to run postion (do not start) hold button until maint lamp goes off - turn key off and release button. maint lamp should be reset
    NWC Member #2
  23. #103
    Feb 2010
    thanks man!!!
  24. #104
    Feb 2010
    heck yeh that worked lol
  25. #105
    Certified Gearhead willard's Avatar
    Aug 2009
    columbus, GA.
    Alright I have a issue i know im gonna have again I cant stop beating the crap outta these mustangs. I dont know what to do tho fix this when I get back HAHHAAAHAHA
    SLEEP, EAT, RACE
  26. #106
    Columbus
    buy a geo metro
  27. #107
    Aug 2009
    columbus, GA.
    GEEEOoooOOOOOOOOOOOO UM sad to say ive seen a metro that can beet mustangs lol
    SLEEP, EAT, RACE
  28. #108
    Mar 2010
    how much does it usually cost to replace a head gasget on a d15? or am i just better off saving a lil more for a swap?
  29. #109
    Columbus
    pretty cheap if you do it yourself, howm uch do you have to work with>?
  30. #110
    TT kte324's Avatar
    Oct 2008
    Columbus, GA
    Quote Originally Posted by 99jdmLs View Post
    i'll do it, just pay me. i got reasonable prices.
  31. #111
    Columbus
    head gasket kit- $111.32 head gasket- $49.46 resurface head if it needs it- $50, $15 just to check it.......i would get the entire kit personally just bc i like to replace all the seals. if its been a while (100k)since your last timing belt, water pump, etc.- it would be a perfect time to do it also.
  32. #112
    Aug 2009
    columbus, GA.
    looking in getting a new clutch for my LS/VTEC W/ LSD any suggestions?
    SLEEP, EAT, RACE
  33. #113
    Hwy 315
    Quote Originally Posted by willard View Post
    Years and years ago i had an Exedy Organic (stg1) coupled to a Fidanza 7lb flywheel - i was very happy with that combination.
    -jonathan
    [/URL]
  34. #114
    Aug 2009
    columbus
    I had a greddy organic to and if you put any extra power behind it at all it wasn't worth a shit... I would buy like a comp stage 4 and 5 bc I know your setup and I know you like going to the track... I know its a little much for an allmotor car but you wouldn't ever need another clutch even if you sprayed or went turbo
  35. #115
    function>form boosted347's Avatar
    Nov 2009
    Columbus, GA
    damn slow mustangs
    1990 Mustang Coupe...turbo lq4 through the glide
  36. #116
    Aug 2009
    columbus, GA.
    Quote Originally Posted by boosted347 View Post
    damn slow mustangs
    Yeah well not everyone can have a Honda I guess
    SLEEP, EAT, RACE
  37. #117
    ah skeet skeet skeet Dicer911's Avatar
    Oct 2009
    Columbus
    I am running and exedy stage 1 clutch with a clutchmasters 7.5Lb flywheel and i have yet to have any problems with it, just a suggestion
  38. #118
    Aug 2009
    columbus, GA.
    Hey anyone able to give me a hand with my car? I finally finished putting my car back together and it is still idling at 2.5k to 3k no vacuum leaks, I installed a 70MM throttle body, and blox intake manifold. I took this thing apart three times now thinking i fucked something up. I'm leaning towards its breathing allot more so I need a tune but not sure. any ideas?
    SLEEP, EAT, RACE
  39. #119
    140 on one wheel
    columbus, ga
    get up with me or justin and we will get it fixed
  40. #120
    Aug 2009
    columbus
    Bring it by and ill fix it
    [SIGPIC][/SIGPIC]
