Page 10 of 16 FirstFirst ... 67891011121314 ... LastLast
Results 361 to 400 of 634
Thread: What the...?
  1. #361
    I keep it real. AFSil80's Avatar
    Savannah
    I read the initial post and saw 9:1 c/r.....so I gotta ask....
    Where are the turbos? Hahahahaha!
    -91 240SX -- CA18 Power...SOLD, now terrorizing the streets of Alabama
  2. #362
    maybe one day. its hard enough just getting it to run in stock form in this car, lol.
  3. #363
    finally, a little bit of update. i decided to tackle some of the wiring since i was waiting on other parts to come in. i focused mainly on getting power to the starter. i took the entire power side off my 4 cylinder harness and wired it up to the neccessary parts on the klde. i was almost there when i ran into one plug that i had no clue where it went to. i knew it was ignition related since it only had power in the on position. well with the help of another bf 323 owner he pointed me exactly in the right direction.
    apparently, its the reverse light switch for the transmission. the reason i couldnt find the plug was obviously because i dont have a 4 cylinder transmission anymore. i simply bridged the two thicker wires and wahlah! with the turn of the key, starter power. at least half way anyway. im thinking my starter might be pooped out. but at least it has power.
    as an added bonus that i didnt even expect, fuel came pouring out through the line. the same wire also powered the fuel pump relay. so power and fuel, so far.
  4. #364
    4 + 2 = 6 SlenderEG6's Avatar
    Warner Robins, GA
    nice
  5. #365
    Certified Gearhead 94ej2's Avatar
    Mobile, AL
    coming together nice louis.
    keep up the good work
  6. #366
    when are you making another trip here?
  7. #367
    Mobile, AL
    not sure. im doing a swap for a guy down here right now then i have to change the head gasket on the yota truck. lol
  8. #368
    Well do it.
  9. #369
    Warner Robins, GA
    bit u know pt dont hang with us any more lol
  10. #370
    Mobile, AL
    Quote Originally Posted by SlenderEG6 View Post
  11. #371
    Slow&InControl! LokiSays's Avatar
    MOAR updates please
  12. #372
    Nothing much going on right now. Waiting on a fuse box to join my 4 and 6 cylinder harnesses. I got my passenger side axle today but realized I still need a half shaft.
    after these things I need a custom radiator and a few other little things and I should be able to at least fire it up.
  13. #373
    stockbridge ga
    Quote Originally Posted by DeeAOne View Post
    well hurry it up.
    i wanna see this bish sometime.
    photoshoot?
    chuck-norris-a-souris
  14. #374
    Zoom Zoom kfzemx3's Avatar
    atlanta
    Did I miss something? Why are you doing a 4cyl and 6cyl harness? This might be a simple thing I'm overlooking but my brain isn't functioning all to well today.
    I spend money on HP not Brand Names.
    08 Infiniti G37s 6MT [The Daily Beast]
    05 Mitsubishi Lancer Evo VIII MR [Sold]
    01 Lexus Is300 [Under Construction]
    93 mazda Mx-3 SE 2.5 Klze [Sold]
    92 mazda mx-3 GS 2.0 Kfze [I Killed it]
  15. #375
    i love the way you flipped it man lol
  16. #376
    Quote Originally Posted by gar9854 View Post
    well hurry it up.
    photoshoot?
    im down with that.
    Quote Originally Posted by kfzemx3 View Post
    i was going to keep the stock alternator, starter, etc. harness from the 4 cylinder. joe advised this. lol
    i do have the entire mx3 gs alternator harness and fuse box on the way though...so which would be easier? mx3 gs power harness or stock BF power harness thats already wired up?
    Quote Originally Posted by Sammich View Post
    what a way to say hey after all this time. lol
  17. #377
    Warner Robins, GA
    or maybe i got a better idea...... take that DE out and get u a ZE with ITBs and run 12s like me
  18. #378
    lol had to make a appearance seeing as though you were doing the v6 swap...how much further do u have to go?
  19. #379
    atlanta
    Ah ok, well if it works I see no reason to change it. I usually see the guys who do the 4cyl to v6 swaps just use the entire harness from the GS thats why I was wondering. BUT no point in spending extra money if the other harness works
    Actually he would be better off just getting a klg4, S rods and some 11:1 pistons. Would be cheaper and yield more power than purchasing a klze.
  20. #380
    Warner Robins, GA
    no.....
  21. #381
    ALL CAPS JITB's Avatar
    i told him to try and see if the bf harness will plug into the GS fuse box.. like the BG one does.. if not than he can get a BG alternator power harness..
  22. #382
    Well the harness came in today. I'll take some pictures for you guys to see what I'm working with. When are you two coming down?! Lol
  23. #383
    Mobile, AL
    updates?
  24. #384
    Hurry up we dont have all day. This should be done by now....
  25. #385
    this is my first swap im trying.
    i havent done much because i need a half shaft. i dont want to risk firing it up with no axle in the trans.
    just to keep you guys happy, a little update
    ordered an egr block off. the weird thing about having the millenia intake on the probe block is that the egr is now in two different places. millenias have the egr on the manifold while probes, mx6s, and 626s have them on the block...so i had to get one for the block as well. the plate on the block is an oem one off a millenia.
    the aftermarket one
    the oem one, tried my best to get a decent picture..
    here's a little taste of the wiring nightmare. im starting to get the hang of it...kinda. i havent really cut deep into the harness yet. where my hand is the part of the harness that i need to dig through. same goes for the other picture with the green and yellow plugs on it. i wont be needing most of that anymore.
    under the dash.
    the new harness and fuse box i have to somehow work in.
    hope to make some real progress soon. ive got to finish taking the 4 cylinder loom apart to keep the necessary wires.
  26. #386
    rolla rollin
    middle GA
    just finish it already! lol jkjkjk
    but seriously its coming along nicely man! id hate to be the one doin the wiring though the only wires i know how to mess with are system wires for subs and stuff
  27. #387
    Middle, Ga
    Damn Louis, you might get this done before I get my Integra done. lol. Progress is looking good. We should try to all meet up and hit up Hooters or something sometime. Been a minute since I last kicked it with you fellas.
    "Damn, Its Tyler"
    RaceReadyDevelopments
  28. #388
    rolla rollin
    middle GA
    ive been waiting till it gets warm before i ask evan when the next meet is lol
  29. #389
    yeah i cant wait until the 323 gets back out on the streets. we will definitely get the warner robins/macon meet back up.
  30. #390
    Middle, Ga
    Quote Originally Posted by J-ROCK View Post
    Why ask Evan? He always had to be home before curfew before everyone even got out there. So I don't think he is a good candiate to be setting up meets. lmao.
    "Damn, Its Tyler"
  31. #391
    rolla rollin
    middle GA
    Quote Originally Posted by NVM View Post
    i would do it but i live in macon and i dont feel like having a meet on zebulon rd lol!
  32. #392
    rolla rollin
    middle GA
    lets do it man!
  33. #393
    guess there is only one person left..
  34. #394
    rolla rollin
    middle GA
    haha just hit me up with a date and time and ill be there!
  35. #395
    did a little work on the car today. i was pretty disappointed on the outcome. i grabbed a halfshaft off a probe at the local junkyard today, and put my mx3 axle into it. i went to bolt it to the block and slide it in the hub. the holes line up perfectly but the the whole setup it too long. i guess i will have to get it shortened. what a set back..
    the hub sticks out much too far.
    this might give a little idea of how far it sticks out.
  36. #396
    Damn that sucks man. Get it shortened so you can crank her up.
  37. #397
    the sky
    good job. reps for you...........
  38. #398
    aye bro .:Stirfry:.'s Avatar
    BIT JUST CUT THAT ISH.
    ATL DAsquad Member #9
  39. #399
    dang that sucks man
  40. #400
    Wont it be more likely to snap if you cut and weld? Good progress though. Hopefully the prelude will be done before the 323. lol.
