theres your problem, all an AFC does is alter the map signal and trick the ECU into thinking that its in a different spot of the map to give you MINOR adjustments in respect to the fuel mixture. It also effects your timing, as different spots of the map require different timing adjusmtents.Originally Posted by jdm>usdm
On a normal car, lets say at 10 inches of vacuum the car is in map "COLUMN A" at 5000 RPMs. Lets say at 5inches of vacuum the car is in MAP "COLUMN B" which takes more fuel and timing at 5000 RPMS. As your load increases so does the fuel and timing (usually). All an AFC does is trick your ecu into thinking that COLUMN A is really "COLUMN B" by altering the map signal. The ecu thinks you are at 5inches of vacuum when you are really only at 10 inches just by altering the signal to the ecu (controlling the voltage). Thats a crude way to explain it but it works.
A programmable ECU like Hondata or Crome doesnt alter the signal at all. It physically controls injector pulse width to determine the fuel you are using.
You also cant compare a SOHC cam to a DOHC cam setup. SOHC has 3 lobes per cylinder(3 lobes to control 4 valves, DOHC has 6 (6 lobes to control 4 valves) (3 lobes intake side, 3 lobes exhaust side)
thats the whole point behind DOHC and VTEC. Maximum driveability, maximum HP.
And no, PRO1s if properly tuned and if they are 0,0, they will idle like stock. I had PRO3s in my 2.0l LSVTEC and it idled at 1000rpms with no lumpiness at all.
I will say this though, there was a bad batch of PRO1s few years back where the centerlines were off. So if you put them in at 0,0 it wouldnt idle at all. It would lump and die consistently. DA_UNKNOWN on here had a set and it was nearly impossible to get his car to idle right. If these are PRO1s from like 4-5 years ago, then its possible. If they are new, then something is not right with the car.
