sucks man! i hope everything is okay. and yea get some better tires.
thanks
cars back together and all good. Only a few scratches.
Yea I need new front tires so I think I'm going to upgrade to some good sticky ones.
Man good tires make a big difference. Glad your ok.
Those look like the mountains out in Helen, correct?
IA's Sexiest Black Man 2009!
From a Boosted Scion tC to a 1JZ-GTE SC300 to 2JZ-GTE SC300
www.asapcarclub.com
www.clublexus.com
yep about 4-5 corners in. This one is the 2nd turn after the first hair-pin turn.Originally Posted by Firefightin_tC
Thats the tire im running on the front. bald BFG G-force sport's on the rear.
^^ dont go to any mtns. lol
I went into the mountains with my car today... and didn't crash this time.
proof
http://www.youtube.com/watch?v=2vI516coROo
http://www.youtube.com/watch?v=BEVZi_bwwBM
nice man .... glad to see it running again ....
93 sol Si
95 sol S
95 sol Si
I hit those same mountains in March...man it's such a blast to come screaming up and down those mountains.
www.asapcarclub.com
www.clublexus.com
I loved it before I put the 15" wheels and kumho tires on my car. Its still a blast.
Today I finally turned over 1000miles on my motor. Geting lost on the way home from the Varsity helped that a lot.![]()
Got some good shot at the V.
Got the trailer hitch on and the wiring harness installed. Its weird seeing a CRX pulling a trailer. LOL
first time i ve seen something like that. kee up the good work
thanks
well everyone's jumping on the bike rack bandwagon and I don't own a bicycle. But I do own a motorcycle so maybe I'll start a new fad. LOL
Finished the light and wiring install on my trailer. Then color matched it to my car. Then went for a test drive with the bike loaded on it. I got to get a bump stop that not cut in half to raise the front of the trail to level it out but other than getting it registered its done..
I get some crazy looks when people drive past me. LOL
lol so cool. more reps.
Haha thats cool man!
JJSPEC Racing
does every light on that cluster work
All that I needed work. I also used the gas light as my vtec light(vtec activates and it lights up) I didn't use the other lights.
what about ABS light and seatbelt and SRS and doors
Didn't need the ABS or srs lights no need for them. the seat belt lights not used because the seat belt wires were all cut and removed from the car when I installed my seats. The Door light doesn't work but I have an interior light so it wasn't really needed. The trunk open lights does work.
cool thanks for the info because i want to put in a teg cluster too
how did you get the turbo and vtec to work together
They work well together. I had the ECU tuned and it made them work smooth. They work weather its tuned or not but having it tuned makes them work together to make the most power.
every read i found on vtec and turbo says it will blow your motor
all vtec does is open the 2nd intake valve and add more fuel at a certain RPM. As long as its tuned properly and you motor is in good shape it will work fine.
If you are using a 94 and up tranny in your CRX, would you have as many problems as you did with the VSS
The D-series VSS will fit into all of the D-series transmissions. It was the wiring that burned up the VSS something was shorting on to the ground circuit and frying them.
Sorry I mean if you used a 94 and up integra tranny?
It cost to much to make them work in the 88-91s to make them worth it for me.
the VSS on the integra tranny should go right to the speedo right no conversions right if you had a motorswap and the motor was a 94 Gsr and so on
I'm not sure
does your ac work
I ripped the A/C out the day after I bought my CRX.
ok why but could you fit it in there with that full size rad and intercooler
Yes you can run A/C with both. But mine was broke and its pointless weight. I have windows and a sunroof. Plus the A/C system weighed over 46LBS thats not including the fluids.
All you need is a a/c computable manifold and downpipe.
so the condenser will fit between the intercooler and rad(can't spell)
yep with plenty of room
did not know it weight 46 lbs but its not like i am racing and do you have a slim fan or reg.
