Results 1 to 13 of 13
Thread: Wrapping a Box
    ellenwood
    Default Wrapping a Box
    How difficult is it to wrap a box with that grey carpet?
    Senior Member | IA Veteran DJ XtRaKŠ's Avatar
    Apr 2001
    Roswell
    i told you...let me build it...but nooooooooo
    IA OG
    ellenwood
    lol then i have to drive all the way up there to pick it up....and fine if you want to and you have the materials then throw one together...you can come to the george jones/confederate railroad concert at lanierland and bring it to me
    Loganville Ga
    Its easy, if it takes you more than 2 tries to get it perfect, you may require a telethon. Go ahead and try it, you can do this fo sho!
    Greg
    86 Buick GN
    07 Passat Wagon
    01 Frontier
    ellenwood
    is it easier to wrap each panel individually then assemble or is it easier to wrap the box once it's fully assembled
    Hiram, GA
    wrao it after its assembled. wrapping each panel will make it impossible to seal
    2_dr_integ
    it basicly like wrapping a present... just use lots of staples...
    respect the TEG
    formerly ATLS2K .....'s Avatar
    in your womans meat curtains
    staples?? Not too sure about that one...I might suggest spray glue...
    John
    --TEAM FUCT OG--
    07' moomba outback v
    02' Xterra
    01' IS 300
    ellenwood
    well you have to staple the back and the bottom...as far as spray glue that's gret until you hit the ends where the fabric stops...you have to use some sort of fastener to hold it there
    Cumming, GA
    If you use decent glue, you dont necessarily need staples. The spray from an aerosol can might not be the best to use here...Maybe something more along the lines of spray glue from a compressor...
    John
    Roswell, GA / Georgia Tech
    I used the spray glue on mine, and it's holding up just fine, just make sure to make your cuts little by little so you don't run the risk of cutting to much fabric off at once. Also the fabric can stretch a little bit, so that helps.
    ellenwood
    screw this....matt i am bringing you a box to wrap soon
    BadAssNinjaTrunkMonkey
    The trick is when you build the box you inset the sides like an 8th of an inch, wrap it like a tube and wrap it over the ends then the sides you stick a piece in there use a tool like a flat head screwdriver and get the fabric in tha corners and trim it up and never use staples it looks like crap use 3m super 99 spray glue its the best stuff that you do it yourselfers can get.
