Results 1 to 6 of 6
Thread: which sub. please help ohm load question
    Senior Member onebadgt's Avatar
    Default which sub. please help ohm load question
    okay so im having a problem here. i am running a kicker 1500.1 amp and it will be on one sub. do i need a dual 4 ohm or 2 ohm sub. i think 4 ohm so i can run it at 2 ohm and utalize all my amps power. because to get all the amps power i would hafta run the 2 ohm sub at 1 ohm and my amp is not 1 ohm stable. so am i right by picking the 4 ohm sub?
    2006 mustang gt
    gears
    bolt-ons
    Yes, that is correct. If you are going to run only one sub, dual 4ohm sub wired in parallel would be the choice if you are trying to get full power out of the amp. If you wanted less power from the amp than 2500rms (birth sheet is a little more), you would want a dual 2ohm sub and wire it in series so the amp will see 4ohms.
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    yeah get the DVC 4 ohm subwoofer, if your amp is not 1 ohm stable you will likely end up damaging it trying to use it at 1 ohm.
    Who knows?
    i have a t3 tss and loved it but it just stopped working so i have the choice of a solo x 2 ohm or a rockford t2 4 ohm so i guess ill run the t2. the solo x wouldnt get enough power runnin at 4 ohm.
    2006 mustang gt
    gears
    bolt-ons
    Between the two, I would go with the T2 anyway.
    hiiiiii
    really i like this topic so much .cars are my weak point .i love to collect cars photos and all.....so pls be connected with me
    __________________
    "For connecting to remote desktop of another computer (via internet or network) and controls. Also connecting to VNCServer through Repeater or directly to VNCServer and a lot of other configuration options.
    For more details VNCServer "
