Results 1 to 16 of 16
Thread: Beginner Stereo setup questions
    Smyrna
    Default Beginner Stereo setup questions
    I'm planning on finally getting around to fixing my stereo since its messed up. But I don't like replacing parts with stock stuff. At the moment, I'm only looking at replacing the stock speakers, tweeters, and head unit. I don't think I'll have any problems installing these, but I have a question about the tweeters in the doors. The two back doors have small tweeters up by the door handle. The one on the passenger side back door is dead, and the one on the driver side back door is pretty close since it goes ballistic when there is any hint of bass. How can I fix/replace these? Oh and what is required to install an amp and subwoofer setup?
    Senior Member | IA Veteran DJ XtRaKŠ's Avatar
    Apr 2001
    Roswell
    no fix for the tweeters get a component system...for amp install you need aftermarket radio, rca's, powerkit, amp and sub (duh)
    IA OG
    Smyrna
    Quote Originally Posted by DJ XtRaKŠ
    I figured as much for the tweeters.... what kind of wiring can I expect when installing an amp & sub? I think I may just replace the speakers and put the rest of my tax return into my Beetle.
    Smyrna
    Okay, I need some advice and opinions on this. I picked out some speakers that good reviews and a headunit that I think is nice:
    Kenwood KFC-1680ie Speakers
    http://www.bestbuy.com/site/olspage....=1134701325409
    Alpine CDE-9870 Headunit
    http://www.bestbuy.com/site/olspage....=1166840027254
    The tweeters in my car are messed up so I'm just going to disconnect and ignore them.
    My budget is around $500 including the above and I want an amp & sub as well. Any suggestions?
    I GOT IT!
    Jan 2003
    Lithonia, GA
    crutchfield sells replacement tweeters from infinity, kenwood, and a few other if you dont want to spend teh money on a full component set.
    Hybridaccord
    PS3 online screen name: Eiswritsat
    Smyrna
    Quote Originally Posted by hybrid90accord
    Well, I want to upgrade the stereo anyways. It sounds bad. I just need to pick a cheap but decent amplifier and subwoofer, and I need to make up my mind if I want to power the speakers with the amplifier. If I only use the amp to power the sub and leave the speakers powered by the headunit, will I have any trouble connecting the speakers to the amp instead of the headunit later on?
    Edit: One more thing - there is a sub/amp combo on crutchfield that I am looking at.
    http://www.crutchfield.com/S-GngCIMg...50&I=700V103XT
    The amp is a 2 channel. I know I'm a noob @ stereo stuff and I want to keep the left and right channels separate to make sure it really is stereo when I hook the speakers up to it eventually. Will there be any problems with this?
    Quote Originally Posted by Magius
    Dont get that for your jetta. First of all visionik is kinda screwy and second of all that is a bandpass box. The ports and everything are intended for an suv or something without a closed trunk. If I see something I will let you know.
    Edit: http://www.crutchfield.com/S-XsxECav...50&I=700PWR299
    Thats not a bad setup. Pretty basic, but a good start.
    ***Lotus Elise***
    BlackWatchRacing
    Smyrna
    Well, its out of my price range now since I have to replace my oil pan. Thats what I get for having a slammed car. lol
    I'm just going to buy the headunit and speakers for now. Will I have any problem with turning it up loud & the headunit powering those speakers?
    That sucks. I dont really think your car is slammed though.
    But as halfwit said an aftermarket head unit will have no problem powering new speakers. And I suggest alpine.
    ***Lotus Elise***
    BlackWatchRacing
    I GOT IT!
    Jan 2003
    Lithonia, GA
    adding a 4 or 2 channel amp in the interior speakers later should be a problem all you will need is a power/ground distribution block, some new RCA, and some speake wire. Is space a/an issue because most bandpass boxes are pretty big. you could probably get the same sound if not louder with a single sub in a ported box tuned for that specific sub.
    Hybridaccord
    stockbridge
    u shouldnt, most aftermarket headunits (unless total crap) have enough output for stock-size aftermarket speakers.
    Smyrna
    Okay, thanks.
    You must spread some Reputation around before giving it to Halfwit again.
    Hampton, Ga
    yes the headunit will push the speakers but not at their full capibilities <sp?> thats why you use a amp?
    Smyrna
    Quote Originally Posted by Wurm
    I was planning on that, but its all gone out the window since I had to replace my oil pan and all.
    Pioneer boo.
    Oh and thats good. If I get another vw I will slam it for sho.
    Eh, I like it. The head unit matches the dash well, sounds good, and has the features I want. The speakers sound good, fit underneath the stock speaker grill and were fairly cheap.
