Results 1 to 12 of 12
Thread: lsvtec boost issue
    Jan 2011
    canton
    Default lsvtec boost issue
    Would having a hole in my rear brake drum line be throwing my psi off?
    What?!?!?!?!?!?!
    BB6 Prelude Srt's Avatar
    Oct 2009
    Hall County
    What?!?!?!?!?!?!
    del sol? 94_teg_ls's Avatar
    /sig
    Jan 2011
    canton
    Idk how the brake booster works..... i was thinking maybe with the brake fluid out it was maybe causing a brake booster vacuum leak and throwing it off....
    Jan 2011
    canton
    anyone?
    Super Certified metalmatt47's Avatar
    Jun 2010
    Powder Springs, Georgia, United States
    Noooooooooooooooooooooooooooooooooooooooooo. Brake booster just uses engine vacuum to reduce effort at the brake pedal and increase stopping power.
    Conformity is the jailer of freedom and the enemy of growth.
    - John F. Kennedy
    Jan 2011
    canton
    Quote Originally Posted by metalmatt47 View Post
    Boost is tied into the vacuum pull of a car. Thats why i thought it might.
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    there is a small grey valve in line of that from the manifold to the booster that is a one way check valve will only use vacume not let boost in so no it has nothing to do with a boost leak! most common causes are bov leak or couplings not tight enough even a compressor housing leak or exhaust leak up stream of turbo.
    Jan 2011
    canton
    Ok. Thanks for your help instead of laughing. On high boost which is twenty lbs, and low boost which is 15lbs it only goes to 13 lbs. On wastegate pressure it goes the full ten lbs that it should. Would it be a leak, or maybe a tune issue?
    LaFayette Ga.
    check your diaphram in your waste gate. seems waste gate related to me.
    Jan 2011
    canton
    Quote Originally Posted by turbob20 View Post
    Ok thanks. Its smoking blueish tinted smoke is why I thought it might be the turbo
