Results 1 to 7 of 7
Thread: b18c1
    F.O.C.U.S jdmshytyo87's Avatar
    Oct 2009
    cedar bluff, al
    Default b18c1
    hi names nate! i was wondering what i could do to my b18c1 for the most power for N/A? its fast as it sits now, i got a few cars around here under my belt with it, i just want to know more about what i can do to it for more power?
    IA Member CodeRED-MVBC's Avatar
    On a train, In a plane!
    internals!! Or boost.. Havent started a build yet.. But it depends on your budget.. If you got it in that EF shell.. You should be fine as it is.. Shits like a jet engine in a shoe box!
    "VTAKS- just like boost with none of the lag...and none of the torque...and none of the boost "
    Oct 2009
    cedar bluff, al
    yea its fast 14.52 was its best time i just wanted to see how a all motor build would go based on opions lol
    Single runner Intake manifold, good header,good exhaust,walbro 190, ITR cams, Hondata and tune and a tune. About 180 wheel would be fun in an EF.
    My line of work
    www.internationaljets.com
    Marietta, GA
    i'm doing a mild gsr build in my integra. crower stage 2 cams, dual springs and retainers, adjustable cam gears, ferrea valves, port and polish, 3 angle valve job, b16 pr3 pistons in an ls bottom end, skunk2 intake manifold, 70mm throttle body and a password whale penis. along with a tune and a chip i will be happily surpassing 200hp. you can do a ton of stuff to a b series motor without going turbo. you won't end up with 600hp, but you will have a solid motor build from the inside out to handle 9,000 rpm easily and still push pump gas. i can only imagine what this kind of build would do in a civic. lots of fun im sure... hope that gives you some ideas.
    all motor power...
    Road to All Motor10s *EFilliated*'s Avatar
    Dec 2008
    Northside
    Bolt ons and stage1 crower cams = my old setup. My shit ran amazing
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    McDonough
    It's a Honda motor....possibilities are endless. Do some research on Honda Tech to see what setups have been built that closely resembles what you want. Bolt ons and a proper tune and you should be good to go.
    Bitches love bacon.
