Results 1 to 22 of 22
Thread: BOV help....
    IA's Pedo-cord tdurr's Avatar
    Fayco
    Default BOV help....
    So the other day i was taking a trip to the store and got into like 3-4lbs of boost and the car didnt blow off like normally.. Then i got into a lil more boost and same thing so i just parked the car.. Could this be a boost leak somewhere? and i checked to be sure the vac lines are hooked up still.
    Save ur engines!
    West palm beach
    what type of BOV ? what do you mean " like normal " ? did it blow off at all ?
    NO ADVERTISING
    -IA MANAGEMENT
    Fayco
    ebay ssqv, no blow off at all.
    Save ur engines!
    Paint me.
    Downtown ATL
    Quote Originally Posted by tdurr View Post
    there's your problem.
    try adjusting the spring, if that doesn't work, buy a new one lol. especially cause i don't want anything to happen to that turbo...
    MCD
    Quote Originally Posted by roche View Post
    stfu....theres nothing wrong with egay
    high gravity ftmfw e30pwr's Avatar
    zone1-6
    and i told you the other day, bosch recirculating unit just vented. screw ebay
    Blog / Don't Click
    Local Photographer
    I <3 Stupid People :boobies:
    Stang Mod slostang's Avatar
    Southside
    yep. time for a new one.
    Fayco
    lol stfu noob. ebay is the shit.
    Quote Originally Posted by e30pwr View Post
    give me the moneis and i will.
    um... see above reply.
    Save ur engines!
    rollin 91 da egpower904's Avatar
    Dallas, GA
    just get a greddy, not much more than an egay. plus i think they have warranties or something. either way hope you get it fixed man.
    Jul 2009
    damn man..... time to take it apart and see if the plastic jank that holds the valve came loose.....
    it does happen.
    theres two parts of the bov
    the diaphram housing and the valve.....
    the valve is rubber with a plastic retainer that holds the rubber in place..... sometimes it breaks or gets stuck your 50% fucked.
    sometimes..... rare.... the diaphram breaks......your 100% fucked....
    you installed the check valve...... 0% fucked..... take it out.
    best way to tell if your fucked is if your getting boost..... if you are.... the plastic things broke or came loose....
    good luck
    Jul 2009
    also if you are using check valves to bypass the factory map sensor your check valves may be fucking up keeping the bov from seeing vacuum.....
    Certified Gearhead redfire6i's Avatar
    southside
    Im all for ebay parts, but the ssqvs are garbage. I think I had to fix mine at least 3 or 4 times before I finally threw it in the trash.
    Fayco
    lol im super late on this thread but it was a mad boost leak and i was too lazy to look hard for it. but its fixed now. and ebay=the shit. thats pretty much how i build my cars...
    Save ur engines!
    and ebay=the shit. thats pretty much how i build my cars...[/QUOTE]
    now thats a man with a plan
    Jul 2009
    good stuff.....
    My Ebay BOV is working better then my Turbonetics did, lol.
    In GA; Missing NJ
    If u buy name brand parts on eBay. U are fine, but using sschrome stuff is a waste of money
    Tim just buy my TurboXS Type H and youll be good to go@!!
    Jul 2009
    my ebay works great
    Fayco
    Quote Originally Posted by civic-r11 View Post
    Quote Originally Posted by mushroom_toy View Post
    just give it to me along with the flange pipe and ill think about putting it on
    Quote Originally Posted by dallasb84 View Post
    my ebay works great
    x2.
    Save ur engines!
    aka....RAFA RJ's325ITS's Avatar
    Stockbridge, Ga.
    See you all wrong, coz you all still use diaphragms... LOL
    that is why I threw away the HKS-SSQ and got the synapse FTMFW
    http://www.synapseengineering.com/ar...01section2.jpg
    http://www.synapseengineering.com/ar...01section1.jpg
    TRM Stage 2 │TRM Coilovers │ TRM Pistons │ TRM Blowthrough Tuning │ TRM MAF & Injectors │ Watch My Crazy Videos
    Fayco
    Quote Originally Posted by RJ's325ITS View Post
    shut up we dont have money like u .
    id kill for a synapse tho.
    Save ur engines!
