Options in taking it off. Shit is horribly stripped.
I need productive answers, comments, and methods.
Methods Ive used.
WD-40
Vice Grip
Methods Ive used.
WD-40
Vice Grip
I would say grind off the head of the bolt to make it square and use a adjustable wrench to try and remove it. Worked for me before. Hope that helps. Use the WD-40 to lubricate it.
Yes, this can work... and if you're good with a grinder/cutting wheel you could also easily cut the nut and just separate it from the stud/bolt.Originally Posted by LokiSays
GL with it!
