Results 1 to 13 of 13
Thread: my current build for my del sol
    F.T.W.K.T.A.
    Dalton
    Default my current build for my del sol
    this is my current set-up, before with out the headers, cam gears, fuel system, and a few out small things it made 156whp and 136ftq.
    im hoping for about 175-185whp this time around what do you guys think?
    if theres anything else i can do to make more power other than going forge at the moment and PnP. let me know. thanx im advance.
    block;
    b18a1 block
    stock ls rods w/ arp rod bolts
    pr3 pistons (11.5:1 comp)
    arp head studs
    LS MLS HG
    p72 oil pump
    p72 water pump
    head;
    gsr head
    crower 402a2 cams
    JUN cam gears
    Ferrea valves
    Supertech springs and retainers
    AEBS intake manifold
    stock gsr TB
    hondata intake mani gasket
    Venom high flow fuel rail
    RC 310 injectors
    walbro 255lph fuel pump
    VtecKiddracing RMF Narrow replica headers
    stock b16 flywheel
    Stage 4 comp clutch w/ heavy duty pressure plate
    GSR tranny
    94 civic Dx 4dr - N/A Ls/Vtec
    91 Accord Lx - Totaled
    Southside Ridin HATCH
    Sounds like a nice setup!!
    reps
    everywhere & nowhere
    402s are gonna be the weakpoint in this build - but GL kid!!!
    YEAH! bRiAnMcIvIcS's Avatar
    Get some skunk2 pro1 cams and maybe the professional products 65mm throttle body(perfect match with your aebs intake manifold and only like $150 shipped on ebay). You really dont need a stage 4 clutch for your set-up a stage 2 would be fine.
    F.T.W.K.T.A.
    Dalton
    well i might pull the clutch when im done building my civic for boost. and probably going with a stage 2. and if i could sell or trade the 402's I'd get some pro 1's. and im think of getting the stepped Tb that got an outside diameter of 74mm then steps into 65 or 68mm.
    Quote Originally Posted by kain86
    you really dont need a really big t/b, 65mm should suffice.
    F.T.W.K.T.A.
    Dalton
    YEAH ILL PROBABLY GO WITH A 65MM SINCE NO PORT MATCHING TO THE TB WILL BE REQUIRED. SO IS THERE ANYTHING ELSE I CAN DO TO MAYBE PUMP OUT A FEW MORE PONIES?
    It's always cheaper to reduce weight than add HP. Put that bitch on a diet.
    F.T.W.K.T.A.
    Dalton
    um its gutted no heater, no ac, no ps. just seats, dash, doors, and steering wheel.lol just wiring seats and a motor lol
    Out in the Boonies
    I agree
    F.T.W.K.T.A.
    Dalton
    WELL JUST GOT DONE PULLING THE SOL APART FOUND OUT THE I CAN PULL MORE WEIGHT OUT OF IT BY REMOVING THE ROAD SOUND DAMPENER FROM UNDER THE CARPET = D NOW FOR MORE POWER! SO FAR MY NEW INCLUDES A 65MM TB, AND SK2 PRO1'S. ANYTHING ELSE YOU GUYS CAN THINK OF LMK. I HAVE TIME SO IM TRYONG TO GATHER SOME GOOD PARTS. THANX
    Make SURE you take a break and add the REAL mods ---> SECURITY!!!!! GL kiddo.
    West palm beach
    x2, also never drive your car to the mall or movie theatre...
