Results 1 to 15 of 15
Thread: Turbo problems?
    Certified Gearhead dm1995's Avatar
    Ga
    Arrow Turbo problems?
    has any one ever had a turbo that wont build boost. It reads at vac 10 and then will het 0 and wont build any boost. anyone know what it could be or have an idea.
    :idb: 95 nissan 240sx SR20det 2002 VW passat 5spd 1.8t
    Certified Gearhead Supacharge's Avatar
    Charlotte
    first make sure your manifold is bolted to your turbo. if you are missing any bolts it will do this. it presents a leak, and therefore wont boost. also check any other piping.
    can you hear the turbo spool at all?
    00 Civic Si turbo
    ls/vtec 592 whp @ 22 psi
    **RLZ ENGINEering**
    Drifter/Kneedragger
    Buford, GA, USA
    check the wastegate actuator to see if it's still connected to the flapper on the turbo... the e-clip likes to fall out and let it separate, thus leaving your wastegate flapping in the wind and no boost.
    otherwise, if you don't hear the turbo spooling check for a blown turbo.
    Banned Jon00's Avatar
    Dec 2003
    Grayson, GA
    its a tail wg i dont think he knows how to hook it up
    Formerly Spyder Man
    Buford, Ga
    Quote Originally Posted by Jon00
    is that for controling poop?
    :boobies:
    Belview Insane Asylum
    Quote Originally Posted by Spyder Man
    BBAAAAHAHAHAHAHAH!!
    Drifter/Kneedragger
    Buford, GA, USA
    if that were the case he'd have blown his shit up already... incorrectly hooked up external gate=BOOM! external gates have only a couple ways to hook them up and they either make the boost you want or a hell of a lot more than you want. due to their design they couldn't hang open unless it were to be opened up and the spring removed completely.
    Dec 2003
    Grayson, GA
    i think it was from the intake manifold to the turbo then a T to the wg (the side port not the top port )
    GSXTACY SilverJester's Avatar
    Acworth
    I would think that with any of these problems you would have hit some psi, just pull off you intake pipe and check for shaft play and/or bent fins.
    Johns Creek
    Are you actually driving the car, or just sitting in the driveway reving it? That does make a difference. And you mean its a Tial wastegate, correct?
    Dec 2003
    Grayson, GA
    Quote Originally Posted by David88vert
    driving the car and yes sorry its a tial
    ck for a blown off chargepipe...usually the most common culprit.
    Certified Gearhead jimjam187's Avatar
    agreed or check the intercooler.
    Duluth, G-nett
    10 at vaccum? seen many cars at 12 vac, did leak down and found out it was piston and oil rings. Should check vac lines and then do compression and leak down test.
    To 942JZGTE 93H22ACX's Avatar
    actually that happened to me... my car was on the dyno and the T4/66 bb turbo wouldnt make boost at all.. it was a new turbo that sat for 1 year.... the shaft was bent... after trailoring home, drove off the trailer... the fins scrapped the housing...
    test the turbo by removing the ic coupler on the side of the turbo hit boost and see if there is enough pressure... if there is then its something else.. if not... we have a brand new full-race T3/67 turbo or used GT40 for sale.....
    good luck
    94 Supra= 500rwhp
