Results 1 to 17 of 17
Thread: compression questions
    blank
    nowhere
    Default compression questions
    if i use 11.0:1 compression pistons in my gsr will it be safe to boost it later on? cp pistons is the plan
    Where we like our sisters...
    i know some people boost type r's but i think they only run like 5 psi stock. just depends on how much boost you want later.
    YEAH! bRiAnMcIvIcS's Avatar
    You wouldnt be able to run very much boost. I would do 9.8:1.
    Are you serious??? That C/R is really high for boost.
    blank
    nowhere
    dead serious. rebuilding the motor. has low compression pistons now. wanting to try higher compression so when not in boost its not terrible
    blank
    nowhere
    what the stock compression for a gsr?? 10.0:1?
    11.0:1 is possible with boost but its gotta be a VERY good tune, not much margin for error or you're in detonation territory. I really like my c/rs to be in the 9.5:1 range for decent out of boost throttle response but also good boost response.
    10.0:1 could be ok if you dont go boost crazy. I would use cp pistons or wiseco pistons and eagle or scat rods. Anything under 9.5:1 will be really sluggish out of boost.
    Whats your power goal?
    blank
    nowhere
    350-400 on high boost. i do want to take it to the drag strip once in a blue moon
    the max id go is 10:1
    u still get good driveability and forged internals will allow u to run a descent amount of boost but yeah, ur gonna need a good tune and descent size turbo so u dnt max out its efficency and start blowing hot air which will increase ur chance of detonating. lol!!!
    i just felt like talking. shitll buff out but if u sked so mutha-dammit!!
    i tried to get 10:1 je's back when i built my first engine and race engineering refused to sell them to me bc i tol dhim i was gonna boost the engine.
    cp's suck!! id get JE's. Not SRP, but JE. Theres a difference in the metals. R&D is what i love. Good luck
    blank
    nowhere
    what is stock compression on a GSR? i wont be boosting for a lil min. gonna take my time and put together a good setup. already have love fab topmount and 4" dp
    11:1 an 10psi is a badass street car with a small turbo
    Cylinder pressure and temps is your main problem.
    id run the 11:1 pistons with a thicker headgasket to get it around 10.5:1-10.7:1
    blank
    nowhere
    i thought thicker headgaskets were a no no. if i run 10.0.:1 or around that. how would if feel compared to a stock motor until i boost it?
    It will run like a 10:1 motor all motor. = slow.
    im doing same thing man, running pr4 rods with GSR pistons in a b18b block for a 10:1 ratio, which is stock for GSR and putting 6psi to it from a JRSC. People boost stock GSR's all the time, so its not too high of a compression to work with, trick is what you already know, the tune. Scotty at mainstream FTW
    02 WRX patrick4588's Avatar
    warner robins
    i was running 9.8:1 cp pistons and the head was milled twice so i would say the compression ratio was over 10:1 and i was running 17psi on 93 octane without detonation issues. i think if you were to use 11:1, just run a simple low boost setup on 93 octane and when you wanted to go to the strip get some 116 octane and turn the boost up.
    GCO Member
    NRA Member
    I had an hks 3 mil headgasket on my stock b16, arp studs and 15psi. i had no problems out of it. well until the oil pump came apart.
    Warner robins ,Ga
    id go 10:1 max on boost. it would be fine NA lol prolly feel like a stock gsr.
